Transmission rebuild
319cssb
221
Easley SC
Has anyone here attempted and graduated in here by rebuilding the alison transmission.
Did you document your progress?
Reworked LMTV
1,124
TN
Oh man. You have to be very brave to work on a transmission. Did it once (not an Alison), never again! Even if you watch a video, there are tons of subtleties (problem areas) that you need to be trained on. Tight clutch packs, wrong steels, kevlar clutches vs the typical, Blah Blah blah.
1. Take it out and have some one bench build "on the side". Meaning find a Alison mechanic who does side work.
2. Grab a used good used one. Lots of people part these out.
Suprman
646
Stratford/Connecticut
I have a good tested transmission here. Still in a truck though. Would be a few weeks before i could get it out. First gen trucks have 3 different variations of trans. Whats your truck year, serial and trans serial number?
Reworked LMTV
1,124
TN
I did a 3060P but that is almost exactly the same. It was completely worn out. Cost about $2k and then $800 for allison to test it.
Interesting. Doubt you did, but did you document the build? Would be nice to share, if you did.
Reworked LMTV
1,124
TN
I hope it rather obvious, just how complex this is. He has rebuilt a lot of these, so it looks easy. The problem is, if you do one thing wrong, it will not shift right, and the whole thing has to come back out.
spankybear
805
WA
How do you take the trans out?
Suprman
646
I usually pull the motor first on a parts truck. If a cargo truck its easier to do trans work with the bed off. Flywheel bolts, bell housing bolts, lines, driveshafts. There is a cross beam over it so you have to slide it back a bit and use straps to lower it down, spin it a bit to clear and slide out.
coachgeo
3,322
North of Cincy OH
saw where someone did this with bed off..... then put cross bracing wood beams above the tranny and put a cherry picker engine puller above it. think he made it in a manner that allowed him to roll it back a bit too.
spankybear
805
WA
Next question is how hard is it to get the bed off?
