- 657
- 1,150
- 93
- Chester County, PA
I proceeded with installing my alternators today... I did not remove all the wiring for the DUVAC yet, but I plan to. I did Ohm wires out and disconnected power and ground to the blue box as well as where it fed into the 12v bus. I'm still waiting on a few things but I made a dry run to check operation. Before starting I checked individual voltages, 12.4 front battery and 12.7 rear battery. After starting front battery was 13.6 and both were 27.8. After running for a while the front voltage was at 14 and both were at 28.1.
I did find that the voltage at the stator taps on the lower alternator was higher than what I should have for a tach reading. I checked the voltage on the upper alternator stator taps and they were good. So I moved the brown diagnostic wire to the upper alternator as that is what I am using inside the truck for a tach signal. Seems to be working although I am going to adjust it a little at idle.
All in all... a successful day! I updated the diagram I made above... proceed at your own risk... YMMV
