muddobber40
- 4
- 18
- la cygne, ks
I know the Cummins swap has been done many times over, but I though I would share my current build. It is at a stand still for now. I have a few turbo conversions to do on a m1009, M1008, and M1028 so it will be a week or so before any more progress is done.
The truck is a 1985 m1028 that had 13,500 miles on it. It has a 4 inch Tuff Country lift running 36x12.50 super swampers
The engine is a 1996 12V Cummins
---upgrades include:
---Killer dowl pin fix
---DAP 5x0.013 Nozzles on new bosch 215 injectors
---4K governor spring kit
---AFC kit.smoke wheel all the way forward until its running to adjust
---60# exhaust valve springs
---2095 rack plug
---timing bumped to 16.25 degrees
--Air Dog II 165 fuel pump/air separator
---1998 power steering pump so we didnt have to booger up the return lines for the hydroboost
---stock turbo for now
Transmssion is an 5 speed Allsion auto from a 2005 Chevy 2500 2wd
Will be using an aftermarket stand alone computer
Transfer case is a Dodge divorce mounted 205
Frame was boxed using another k30 frame from the rear cab mount crossmember to the front shackles. I used some factory frame braces off an 86 frame to fill the void between the Auto World engine cross-member to where the added frame ended. I made the trans and transfer cross-members...not proud of the transfer mount but it will work.
I will add pics once I get more work done next week. I can also get more pics of what ever anyone would like
---2095 rack plug
