Page 415 of 427 FirstFirst ... 315 365 405 411 412 413 414 415 416 417 418 419 425 ... LastLast
Results 4,141 to 4,150 of 4268
Thread: FLU419 SEE HMMH HME Owners group
  1. #4141
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    Quote Originally Posted by Pinsandpitons View Post
    There's a spare pulley on the crank, I could drive the new one with two belts.
    I think that Idea is a non starter, because the spare pulley is of a much smaller diameter. You might be able to break down the stack of pulley's and make them the same size, but don't count on just slapping another belt on it won't work.
  2. #4142
    Sergeant MadCat2's Avatar
    Join Date
    Nov 2012
    Rome, PA
    Posts
    75
    Thanks
    Default
    new 419 SEE owner, Rome PA, USA. Need help w parts, needs a lift pump- I have it bypassed but want to fix that, and it overheats- what T-STAT does it take?
    SGT Tew
    US ARMY Retired
    FFL DLR, Tew's Armory
    HAM- K2TEW
    OT-90 Czech IFV
    M936 Wrecker w MEP 025A
    FLU 419, Small Emplacement Excavator
    M105 Trailer
    (2) M103a3 Trailer
    XM106 Trailer
    (2) S-280 Shelters
    MEP-003 Generator w trailer
    Large Light Weight Maintenance Enclosure
  3. #4143
    General
    Join Date
    Oct 2014
    northern nh
    Posts
    456
    Thanks
    20
    Default
    Quote Originally Posted by The FLU farm View Post
    If you find the entire loader with a bucket, which is probably far more likely, I'd be interested in the loader part.
    There is an entire loader for sale on Unimog Exchange
    Unimog SEE, Unimog 1300L Ambulance
  4. The Following User Says Thank You to peakbagger For This Useful Post:
    The FLU farm (01-07-2019)
  5. #4144
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    Quote Originally Posted by MadCat2 View Post
    Welcome to the group MadCat2
    there is lots of info on SEEs on this thread.
  6. #4145
    2 Star General Migginsbros's Avatar
    Join Date
    Nov 2013
    Berlin-Germany
    Posts
    632
    Thanks
    808
    Default
    MadCat2, welcome to the thread. Greetings from overSEEs.
  7. #4146
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    Would anyone like to express an opinion on what I should torque the bolts that hold the access cover to the transmission with a cork composite gasket. I have searched the TMs but not found anything regarding the installation of the access cover. The torque values would probably be too high anyway because the OEM was some kind of plasticized paper / fiber. I looked for an OEM but gave up fairly quickly and just made my own. For reference this is what I am talking about.
    I am guessing around 5-10 pounds. I used a thin coat of Permatex aviation liquid sealant and added lock washers to make up for reduced torque. When I installed it I mated up the materials and put the bolts an washers on finger tight and left it set for an hour or so be for tightening 1/4 a turn at a time on opposite sides of the plate. I just tightened it enough to depress the spring in the lock washer. I did not put a torque wrench on it, just kinda guessed on what was equivalent force. I intend to go back over it with a torque wrench once I decide on a value. Any comments on the process I followed are welcome.
    As a tip to anyone that needs to do the same thing, a spent 45 ACP is perfect for cutting the bolt holes. Just line up the access cover with the gasket put the 45 in the bolt hole and give it some love with a rubber mallet.
    Attached Images Attached Images
  8. #4147
    4 Star General The FLU farm's Avatar
    Join Date
    Dec 2015
    The actual midwest, NM.
    Posts
    2,424
    Thanks
    1,055
    Default
    Quote Originally Posted by rtrask View Post
    I generally tighten most fasteners until they start turning freely, then back off half a turn.
    You may want to use less torque.
  9. The Following 2 Users Say Thank You to The FLU farm For This Useful Post:
    Guyfang (01-09-2019), rtrask (01-09-2019)
  10. #4148
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    I'm kinda dense, FLU farm, I am not sure what you mean, or if you are joking. My tendency is to over torque. When I tighten until it turns free it means I've either snapped the head, or stripped the threads. In either case backing off a half turn doesn't do me much good. But if you are not ribbing me, can you explain what you do mean?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  11. #4149
    Join Date
    Dec 2015
    Posts
    2,424
    Thanks
    1,055
    Default
    Me? Ribbing you???
  12. The Following User Says Thank You to The FLU farm For This Useful Post:
  13. #4150
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    Me? Ribbing you???
    OK, that's what I thought. I will start snapping the bolt heads off so I can determine what a half turn less is. I will go a head and buy a new roll of cork composite now. You are my hero.
    Since it is now officially on the internet it must be true.
  14. The Following 2 Users Say Thank You to rtrask For This Useful Post:
    Guyfang (01-09-2019), The FLU farm (01-09-2019)
Similar Threads
  1. Unimog FLU419 Tractor thing?
    By jluv1185 in forum Unimogs
    Last Post: 04-06-2018, 14:02
  2. HME, SEE, HMMH same chassis?
    By wehring in forum Unimogs
    Last Post: 01-03-2016, 16:36
  3. Replies: 5
    Last Post: 05-21-2013, 07:16
  4. FLU10344 (HMMH) video
    By forestMog in forum Unimogs
    Last Post: 11-06-2011, 00:41
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
