Page 335 of 442 FirstFirst ... 235 285 325 331 332 333 334 335 336 337 338 339 345 385 435 ... LastLast
Results 3,341 to 3,350 of 4415
Thread: FLU419 SEE HMMH HME Owners group
  1. #3341
    2 Star General General Hood's Avatar
    Join Date
    Jun 2015
    Fort Towson, OK
    Posts
    711
    994
    Default
    Quote Originally Posted by alpine44 View Post
    What is the Texarkana method as it relates to stowing/deploying the backhoe implement? Does it involve a forklift?
    maybe
    Lonnie KF5PVV
    11th ACR - early 70s
    1987 M923A1
    1990 M923A2
    1989 FLU419
    1988 M998
    1986 M105A2
    2008 M1101
    2006 M1101
    1991 M101A2
    2010 MEP803A
    "5 second fuses only last 3 seconds"
  2. #3342
    4 Star General The FLU farm's Avatar
    Join Date
    Dec 2015
    The actual midwest, NM.
    Posts
    2,595
    1,219
    Default
    Quote Originally Posted by rtrask View Post
    I have read that section multiple times and the light did not click until just now.
    I thought you knew, Ron, but used this as an excuse to leave the backhoe out and on the ground as an anti theft device, General Hood style.
  3. #3343
    Join Date
    Dec 2015
    Posts
    2,595
    1,219
    Default
    I looked at the parts manual but could not find anything that jumps out.
    It's been a while since I looked at the hydraulics diagram, and I wasn't looking for anything in that circuit, but since it acts and sounds like there's a restrictor in there somewhere, I'm pretty sure there is one. Whoever finds it first, please let us know where.
    I'll try without the restrictor first, but if that turns out to be too fast to control, it's easy enough to enlarge the orifice in the restrictor and reinstall it.
  4. #3344
    Colonel alpine44's Avatar
    Join Date
    Jan 2014
    Asheville, NC - Elkton, MD
    Posts
    392
    Default
    Quote Originally Posted by The FLU farm View Post
    Where did you find the hydraulic diagram?
    1990 FLU419 SEE
    1986 M1009, 6.2L engine, 700R4/NP241, 4.10:1 14 bolt 8 lug rear, 10 bolt 8 lug front, 4" lift, 34.5" tires
    1993 M998 2-man troop carrier - SOLD
    MEP002A generator
    Gichner Expandable ISO shelter = my machine shop
  5. #3345
    Join Date
    Dec 2015
    Posts
    2,595
    1,219
    Default
    I knew you would ask...and I wish I could remember where I found it. Or if was even FLU specific. After two years of searching for FLU info I've unearthed a fair amount, much more than my brain cell can contain.
    I'll search the folder of saved stuff later, okay?
  6. #3346
    Join Date
    Jan 2014
    Posts
    392
    Default
    Had a good, productive day today.
    First, I created some water diversions with the backhoe by positioning the FLU419 at the drain side of the diversion and fully extending the bucket to act as a scraper. Then pulling in the fully extended dipper while adjusting the boom height and turning the hoe towards the desired drain point. After some cleanup with shovel and rake the diversion looked pretty good for the first try.
    Back in the shop I put new hoses on the Stanley hydraulic chain saw and got the chain oiler working again. Cut a couple of logs apart to test. The saw is not going to compete with my 440 Stihl for heavy work but is nice for bucking and de-limbing smaller stuff. The advantage of the Stanley is that it is always there when needed, and does not need a jug of gas and bar oil.
    After that I wired up a wireless winch control to the UP-DOWN switch for the bucket. That will allow me to get up into the trees and use the newly acquired hydraulic pole saw. Still waiting for the correct QD fittings to arrive to test that baby.
    Only annoying thing was that I had to clean the fuel strainer next to the tank four times and wipe the small rust flakes off the screen. Next week I am going to be near my boat stuff and will check whether a bigger Racor water/gunk separator can be fitted in lieu of Mercedes' excuse for a strainer.
    1990 FLU419 SEE
    MEP002A generator
  7. The Following User Says Thank You to alpine44 For This Useful Post:
    General Hood (08-02-2017)
  8. #3347
    Join Date
    Dec 2015
    Posts
    2,595
    1,219
    Default
    After that I wired up a remote winch control to the UP-DOWN switch for the bucket. That will allow me to get up into the trees and use the newly acquired hydraulic pole saw.
    OSHA approved, no doubt. And that alone makes me want to copy your idea.
  9. #3348
    4 Star General Another Ahab's Avatar
    Join Date
    Jan 2012
    Alexandria, VA
    Posts
    15,552
    22,714
    Default
    That's surprising that Daimler-Benz would go so cheap on a critical piece of engineering like that:
    - You know, their U.S. marketing message is "the best or nothing"
    But clearly the marketing is fluff, or sure seems so.
    M35A2 w/Winch SOLD
  10. #3349
    Join Date
    Jan 2014
    Posts
    392
    Default
    Fortunately, OSHA does not have any jurisdiction in my neck of the woods. However, I made a sketch of a quick attack guard rail that turns the self-leveling loader into a decent aerial bucket. A safety harness is not going to be very useful if you come to rest face to face with the loader teeth.
    1990 FLU419 SEE
    MEP002A generator
  11. The Following User Says Thank You to alpine44 For This Useful Post:
    The FLU farm (08-02-2017)
  12. #3350
    Join Date
    Jan 2014
    Posts
    392
    Default
    Quote Originally Posted by Another Ahab View Post
    "Nothing" would almost be better than this clog-o-rama.
    1990 FLU419 SEE
    MEP002A generator
  13. The Following User Says Thank You to alpine44 For This Useful Post:
    Another Ahab (08-02-2017)
Similar Threads
  1. Unimog FLU419 Tractor thing?
    By jluv1185 in forum Unimogs
    Last Post: 07-21-2019, 16:39
  2. HME, SEE, HMMH same chassis?
    By wehring in forum Unimogs
    Last Post: 01-03-2016, 16:36
  3. Replies: 5
    Last Post: 05-21-2013, 07:16
  4. FLU10344 (HMMH) video
    By forestMog in forum Unimogs
    Last Post: 11-06-2011, 00:41
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
