FLU419 SEE HMMH HME Owners group
MogPoggers
81
Jamestown, New York
You're braver than I am. A friend has tried letting movie people use his vehicles, and it did not end well.
I keep getting requests for using some of my cars in films, but decline...even if I'm the only one allowed to drive them. Sure hope it works out for you.
That's something I hadn't considered before... that people might want to use the SEE in movies, etc. But yeah, I'd be leary about it like you.
I'm still here, BTW, in case anyone wondered (I'm sure they didn't). I'm watching the thread. I just haven't had anything to add lately, especially since we're still in limbo in this damn rental for another couple of months. The real fun won't start until I have the SEE out on my own land.
MogPoggers
81
Jamestown, New York
so my leak was not a real leak. The air line to the hub had a tear in it. I guess there's some gear oil that moves through the 4 wheel drive side of air system? I patched it up and no more oil. My next problem will be adressing the pto pump. It has started to leak but I can't tell where from. I believe tilting the cab is in my future. View attachment 921337
If you tilt the cab, can you document that process? I've seen a few times where people did it, but I'm still not 100% on all the steps. I don't need it yet, but I'm not fooling myself - we'll all have to do it at some point I'm sure and the more documentation the better.
MogPoggers
81
Jamestown, New York
I'm very new to owning an SEE, so I'm reticent to offer information for fear of being wrong, but just from my general knowledge of how things work, I don't believe there should be any oil anywhere in the pneumatic lines.
If you were seeing something leaking from the pneumatic hose(s), I think it's one of two things - either condensation (water), or possibly alcohol. There is a small filler cap on the passenger side of the vehicle up top next to the backhoe seat. Alcohol is added into the pneumatic system through this cap to prevent freezing in cold temps.
If I am wrong, I'm sure I will be corrected shortly.
peakbagger
345
northern nh
Keep in mind, there are set of front pivot brackets required to lift the cab, they act as hinges. There are also prop rods required to hold the cab forward in tilted position. Without them or something equivalent very bad things can happen. I think most folks just rig up their own prop rods.
What you want is one of these kits that are no longer available TILTING DEVICE-419580055100 (expedition-imports.com) Expedition Imports just leaves the listing to taunt us :)
One of the members on this forum developed and supplies the tilt bracket set to Expeditions Imports Cab Tilt Bracket Set - 419-CABTLTST (expedition-imports.com)
The SEE manuals give a very detailed description on what steps are required to tilt the cab. Do note the ROPS needs to be removed.
