Page 434 of 441 FirstFirst ... 334 384 424 430 431 432 433 434 435 436 437 438 ... LastLast
Results 4,331 to 4,340 of 4409
Thread: FLU419 SEE HMMH HME Owners group
  1. #4331
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    181
    112
    Default
    Quote Originally Posted by The FLU farm View Post
    I'm really tired, but isn't 87 normally "power out"? In other words, it is only carrying power when the relay is energized.
    Correct, 87 is out when the relay is energized. 87a is out when the relay is not energized. Because the relay is energized it is sending the 24 volts that would normally go to the start button to the cold start set of circuits, the red line remains at 0. If I remove the light blue line then the red line is at 24 volts and the starter button works.
  2. The Following User Says Thank You to rtrask For This Useful Post:
    Guyfang (06-12-2019)
  3. #4332
    Sergeant
    Join Date
    Aug 2018
    Nebraska
    Posts
    70
    Default
    the lubrication guide shows OE/HDO-10 as the lubricant for the power steering. So does that mean i should just run a 15w40 or can i run the same AW32 hydraulic fluid I'm running in the backhoe since that system also originally called out OE/HDO-10
  4. #4333
    Sergeant Major
    Join Date
    Dec 2017
    Central Washington
    Posts
    108
    22
    Default
    Since no one else has swung at this... If it were me and I was swapping fluid out, I would run the AW32 in it. It's a hydraulic system after all. The only reason (as I understand it) that OE is called for is the simplified logistics of using the same fluids for many things. I'm confident that OE would do no harm, but hydraulic oil has better anti-corrosion additives and tends to deal with water vapor a bit better. Also I have heard that regular motor oil (as we know it) has detergents that can screw up non filtered systems like air compressors, and such because the detergents keep gunk in suspension and abrading parts rather than getting filtered out (as with a filtered system) or sinking to the bottom (in unfiltered things). This info is worth every nickle that you paid for it.
  5. #4334
    4 Star General The FLU farm's Avatar
    Join Date
    Dec 2015
    The actual midwest, NM.
    Posts
    2,593
    1,216
    Default
    I agree. Running AW-32 in mine.
  6. #4335
    General Speedwoble's Avatar
    Join Date
    Jan 2009
    New Holland, PA
    Posts
    406
    66
  7. The Following User Says Thank You to Speedwoble For This Useful Post:
    Another Ahab (06-24-2019)
  8. #4336
    Join Date
    Dec 2015
    Posts
    2,593
    1,216
    Default
    A bit brutal with the levers, maybe, but it worked.
  9. #4337
    Sergeant Major
    Join Date
    Dec 2017
    Central Washington
    Posts
    108
    22
    Default
    Because a beverage is always invited.
    It’s a cup holder.
  10. The Following 4 Users Say Thank You to Pinsandpitons For This Useful Post:
    Another Ahab (06-24-2019), BradIXXI (08-18-2019), kira2235740 (06-24-2019), The FLU farm (06-24-2019)
  11. #4338
    Potato Peeler Sgt Jiggins's Avatar
    Join Date
    Feb 2019
    Lynchburg, VA
    MVPA
    24241L
    Posts
    189
    459
    Default
    I have avoided the cupholder. Because I didn’t want any cans finding their way in there ...
  12. #4339
    Join Date
    Feb 2019
    Lynchburg, VA
    MVPA
    24241L
    Posts
    189
    459
    Default
    I have avoided the cupholder. Because I didnít want any cans finding their way in there ...
  13. #4340
    Sergeant Major
    Join Date
    Dec 2017
    Central Washington
    Posts
    108
    22
    Default
    Yes, there is a strict “no soda pop” policy in place now. The price of progress.
  14. The Following 2 Users Say Thank You to Pinsandpitons For This Useful Post:
    Sgt Jiggins (06-25-2019), The FLU farm (06-24-2019)
Similar Threads
  1. Unimog FLU419 Tractor thing?
    By jluv1185 in forum Unimogs
    Last Post: 07-21-2019, 16:39
  2. HME, SEE, HMMH same chassis?
    By wehring in forum Unimogs
    Last Post: 01-03-2016, 16:36
  3. Replies: 5
    Last Post: 05-21-2013, 07:16
  4. FLU10344 (HMMH) video
    By forestMog in forum Unimogs
    Last Post: 11-06-2011, 00:41
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
