Using a 24v Battery Charger via the outside slave cable port
joesco
Hampstead, NH
I have done a search and know this has been done before, but can't find specifics. I just purchased a NOCO Genius 12v/24v Smart Battery Charger / Maintainer and would like to charge / maintain (24v) my four Hawkers (installed in 2010 by Uncle Sam) via the slave port on the passenger side. I know I will need to purchase a male plug and wire it to my charger cables. My question.... has anyone done this? How do I wire it to the male plug (two wire??) and what gauge wire would I need. Thanks very much!
1,814
In a NATO plug, the center hole is positive while the surrounding part is negative.
MWMULES
344
DESOTO, KANSAS
A G26000 will work through the Nato plug, a standard 24V charger would work also. A gen 4 bank charger with a set of wires to each battery would be better.
joesco
Hampstead, NH
One more question.... being budget conscious, I found this connector online for short money. Are all NATO Slave Receptacles the same? My truck is a M931. HUMVEE NATO Slave Receptacle J-6362/U 24V Connector
1,168
Always confirm connections with a meter. I've seen the nato plug wired incorrectly on more than one truck!
steelandcanvas
85
Southwestern Idaho
Yes, all NATO (North Atlantic Treaty Organization) Slave Connectors are the same. This is standardized to work with all our allies in NATO.
MWMULES
344
DESOTO, KANSAS
That plug would work for dumb charging but not for slaving, low amp plug. Not all plugs are the same there are high and low amp plugs the J-6362/U 24V is low amp, if you hooked 2 of those up with cables and tried to slave a truck one end or the other would melt to the male plug.
joesco
Hampstead, NH
Thanks, it will only be used for my new 24v charger / maintainer. Saw these slave plugs con the manufacturer's website for around $250.00, bought it new for $47.50!
joesco
Hampstead, NH
See my pics below, installed today. The Humvee Nato (new $47.50) Slave Receptacle J-6362/U 24V came with a fused-in electrical power cord which would have plugged into a 24v charger. In about 5 minutes, I removed the screws on the back of the Receptacle, removed the power cord, and installed the my charger's cable (red to red, black to ground). I then plugged the new Receptacle into the side of the truck and using a multi-meter I tested the new charger's pigtail cable pins and it showed 24.8 volts coming off the batteries in the truck. So I knew my truck's Receptacle was wired and working correctly.
I plugged in my charger and set it to 24v Normal and it began conditioning and charging! Really neat, thanks for all the help on this guys!!!
Maverick1701
181
Lubbock, TX
Thanks for posting this thread. I am also looking for battery charging/maintaining options for my Jeep. I may end up copying this idea...only with the correct slave plug for my Jeep.
datadawg
Bucks County, PA
Why would the GEN4 be better? You have to wire up each battery (more hassle) and according to their website, it's recommended only for battery maintenance, not charging (See the charging chart at bottom of page: https://no.co/g4)
The G26000 seems to offer more power and have additional versatility for civvy use (jump starting a dead battery), and with a NATO plug can be just as easily used to charge the 5 ton batteries. What am I missing?
NEIOWA
115
NE IOWA
Because you're testing/charging each battery individually based on it's condition.
Your option (plan B) is treating the battery bank as one big 24v battery which it is not. It is 4x 12v batteries interconnected. Can you correctly assume that all the batteries were identical in identical condition? Unlikely and they are $250ea Plan B works until it doesn't, at which time you won't know if plan A would have worked out better or not.
ericp351
57
erie Pa
Worked with many large battery system on ships to start stby diesel. Used one charger per battery bank. Not perfect, but worked well.
FloridaAKM
392
Gainesville, Florida
I charge my trucks by this method thru the slave port & have no problems with either the LMTV or the Deuces. Love the charger by the way, it is by far the best charger I own.
View attachment 483360View attachment 483362View attachment 483361
