- 8,272
- 606
- 113
- Corpus Christi, TX
My second frustration and this one may not have a resolution. BTW, been working this issue for over a month.
Looking for the NSN's for the components of the Soldering Torch Kit.
3439-00-542-0531 B X U EA 1 1
TORCH KIT,SOLDERING, C/O DISPOSABLE FUEL CYL,BURNER UNIT, PENCIL BURNER HD, UTILITY BURNER HD, SOLDERINGTIP,FLAMESPREADER,FLINT LIGHTER,PLASTIC OR METAL CASE
The flint and spark igniter are based on the other torch kit so may not be correct. The propane refill cylinder is correct. If anyone has any info....I again tried all the usual sources. Looking for the NSN's and the model numbers are posted.
6830-00-584-3041* C* X* U* *EA* 1* 1 PROPANE, GAS REFILL CYL, 2-3/4 IN. DIA, 10 IN. LG 26.7 FLUID OZ FUEL*
UL2317 C* X* U* *EA* 1* 1 PENCIL FLAME JET TORCH
810 C* X* U* *EA* 1* 1 FLAME SPREADER
tx405 C* X* U* *EA* 1* 1 5120-00-965-0326 SPARK/FLINT LIGHTER
TX406 C X U EA 1 1 5120-00-965-0603 FLINT RENEWALS
C* X* U* *EA* 1* 1 CASE, CARRYING
650 C* X* U* *EA* 1* 1 UTILITY FLAME HEAD
JT869 C* X* U* *EA* 1* 1 SOLDERING TIP
