Keith_J
- 1,313
- 113
- Schertz TX
Most rigging calcs are fudge factors. As are winch ratings but you should count on at least 12k of pull bare drum. Each block must be rated for twice that or 24k, more important is sheave diameter which should be equal or greater than the winch bare drum diameter.
Sure, calcs may show a little over 8k of pull is needed but that is for smooth ramps, most aren't. So you might need 2 part.
