- 3,574
- 5,111
- 113
- MA
Here is a DIY load bank setup that you can adjust and break down as needed
(1) https://teamequip.com/genpro-gillet...240-volts-out/#mz-expanded-view-1248727738663 (*it has a make offer function, I bet they would take $100 for one looking at their stock levels)
(up to 4) https://www.runnings.com/comfort-zo...lyjYLGEUVT7uMLTGeLmLDvsrD2WFPNIk99IIJ2P3O9cP8
The spider box is perfectly sized for the 802, you would just need to make a cable to go from the machine to the box (but that would be the same cable you would use to your home, if not hard wiring it). The milkhouse heaters can be set to either 1300W or 1500W each. The box holds up to (4) standard 3 prong US plugs. You would just need to make sure the breakers will carry the load.
But this not only is deployable as you want, but also gives you future ability to run external load items off the 802, without overloading the convenience outlets near the gauges.
