Page 15 of 15 FirstFirst ... 5 11 12 13 14 15
Results 141 to 148 of 148
Thread: Cummins 6CTA8.3 Injection Timing
  1. #141
    Colonel adamsoffroadperformance's Avatar
    Join Date
    Jan 2009
    New Enterprise Pa
    Posts
    355
    Thanks
    126
    Default
    I know several shops that use a cam degree wheel bolted to the balancer. then no need to measure the balancer just bolt the wheel on and make a pointer. degrees position doesn't change by diameter when your going off the face instead of the side of the balancer
  2. #142
    General CARMAN's Avatar
    Join Date
    Oct 2017
    Bristow, Va
    Posts
    580
    Thanks
    264
    Default
    Just read 15 pages and whaaat? The suspense was killing me! I have a large Cummins only shop down the street. Maybe I will stop in and ask about the turning up on the 8.3 and see what they say since I am now full of knowledge. Just no guts to try it on my own.
    M923A2
    S-280
    M1101
  3. #143
    4 Star General 74M35A2's Avatar
    Join Date
    Oct 2013
    Livonia, MI
    Posts
    3,906
    Thanks
    440
    Default
    There is another path to doing it. The injection pump timing can also be adjusted inside the pump by a calibration shop with a pump flow bench. You can pull the pump, and send it to a pump shop. Tell them it is currently timed at 8 degrees, and you want it timed at 16 degrees instead. They will make the change to the pump. Then you just install the pump using the 2 plastic push-in timing pins, already on the pump and engine. I think I was quoted $100 to have this done. Gravy.
    Sorry I stopped on it. Iím changing engines instead of modifying my stock one.
    CFO @ Portacharger
  4. The Following User Says Thank You to 74M35A2 For This Useful Post:
    Csm Davis (10-07-2019)
  5. #144
    Join Date
    Oct 2017
    Bristow, Va
    Posts
    580
    Thanks
    264
    Default
    Yes had seen that idea in the thread. Still got to get that brake drum thing worked out. Just been working on cosmetic stuff. Then performance next. Picked up some extras up in PA this week. I had seen someone in the thread ask about exhaust delete. Any issue with just replacing muffler with a straight pipe? Don’t really need the back pressure for down shift. I’m sure it will sound good like my 2500 Ram.
    M923A2
    S-280
    M1101
  6. #145
    General
    Join Date
    Jul 2005
    Derry, NH
    Posts
    522
    Thanks
    40
    Default
    What's all the boo-hah-hah about now? There are many trucks out there with 16+ degrees of timing... there are many ways to get it done. I love mine, but did way more than just timing.
  7. #146
    Private
    Join Date
    Mar 2017
    sandgate vt
    Posts
    Thanks
    Default
    i have 4 inch to 5 inch under the cab with no muffler.
    i also have a 2016 ram full delete no muffler. the dodge is not loud at all. the 5 ton is about at my limits for sound..
    I cut open my stock muffler and cut the crap out of it and welded it back up. sounded good and egts dropped a bit. egts drop even more with straight pipe.
    i would gut the stock muffler. or buy my old one ! I may put a resonator on the straight pipe to help with the drone.
    Quote Originally Posted by CARMAN View Post
    Yes had seen that idea in the thread. Still got to get that brake drum thing worked out. Just been working on cosmetic stuff. Then performance next. Picked up some extras up in PA this week. I had seen someone in the thread ask about exhaust delete. Any issue with just replacing muffler with a straight pipe? Donít really need the back pressure for down shift. Iím sure it will sound good like my 2500 Ram.
  8. #147
    Join Date
    Oct 2017
    Bristow, Va
    Posts
    580
    Thanks
    264
    Default
    Ok. May try. I run all the delete on my 2011 dodge ram.
    M923A2
    S-280
    M1101
  9. #148
    Corporal
    Join Date
    Mar 2017
    California
    Posts
    Thanks
    Default
    Bump for easier reference.
  10. The Following User Says Thank You to 1Sinner For This Useful Post:
    CARMAN (10-03-2019)
Similar Threads
  1. Cummins 6CTA8.3 Modifications Beyond Pump Adjustments, Anybody Done Any?
    By 74M35A2 in forum 5-ton Mods and Hot Rodding
    Last Post: 02-29-2016, 13:06
  2. turning up Cummins 6CTA8.3
    By jayjaytocool in forum Mechanical Upgrades
    Last Post: 02-16-2010, 22:37
  3. injection pump timing
    By mucekok in forum The Deuce
    Last Post: 12-23-2006, 21:00
  4. Injection pump timing
    By Aknoll007 in forum The Deuce
    Last Post: 06-08-2006, 20:43
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
