Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 21 to 30 of 110
Thread: G506 Class 525 (G7133) restore
  1. #21
    Senior Chief/Moderator hndrsonj's Avatar
    Join Date
    May 2004
    Cheyenne, WY
    MVPA
    31099
    Posts
    7,379
    Thanks
    977
    Default
    Problem is: do you have a bed if you made a cargo truck?
    1951 Reo M48 Deuce Tractor
    1962 Dodge M37B1 w/w
    1951 Willys M38
  2. #22
    4 Star General jeffhuey1n's Avatar
    Join Date
    Mar 2010
    Laramie County, Wyoming
    Posts
    1,150
    Thanks
    847
    Default
    Nope, don’t have a bed. In 1944, the bed would have been made of wood. The fire truck would have had a flatbed with the water tank and stuff attached. It’s a 50-50 shot on which way to go. The fire truck may be slightly less difficult than because a flat bed is significantly easier than trying to build the cargo bed from scratch.
    3 each M35A2's 2 WO/W, 1 W/W:
    1972 M35A2 WO/W “Toys For Tots”, aka “Armadillo”
    1972 M35A2 WO/W “Tribute to Lt Col Ken Bourland”, aka “Warthog”
    1970 M35A2 W/W “War Wagon”, Vietnam War Gun Truck Tribute
    1 each M59 gasser dump truck
    2 each M211's 1 W/W, 1WO/W
    1 each M52A2 tractor
    1 each M1009
    1 each M37, with Dodge poly 318, hydraulic clutch
    1 each G506 Fire truck “Sparky”
    USMC/USAF
  3. #23
    Join Date
    Mar 2010
    Posts
    1,150
    Thanks
    847
    Default
    I decided I split the difference. I’ll remove the frame extensions from the front, bring the bumper back and attach it to the original mount holes then use the various fire truck components and build the back of the truck to look like the original. I have an old gasoline powered water pump from another fire truck that I’ll install to give the truck some “real world” functionality.
    Attached Images Attached Images
    1 each M1009
    USMC/USAF
  4. #24
    Join Date
    Mar 2010
    Posts
    1,150
    Thanks
    847
    Default
    It took almost two hours to grind off the last two welds of the second frame extension. Next step is to clean all the white and red paint and prep for eventually painting everything OD green. The engine, other than heavy layers of dirt and oil, is a nice Chevy orange. I can’t wait to see it all cleaned up. Okay, I can wait, it’ll test my limited patience.
    1 each M1009
    USMC/USAF
  5. The Following User Says Thank You to jeffhuey1n For This Useful Post:
    wrenchturner6238 (02-08-2019)
  6. #25
    Join Date
    Mar 2010
    Posts
    1,150
    Thanks
    847
    Default
    Started stripping paint off the front bumper. Tried a couple different ways but they really didn’t work well. I have a couple Course Roto Strippers, CG-1. They take that old red and white paint off like nobody’s business! Now to find a source of them ‘cause they’re going to wear out before I can finish getting rid of all that nasty red/white paint. No pictures tonight. Might have something worth taking a picture of tomorrow.
    1 each M1009
    USMC/USAF
  7. #26
    Join Date
    May 2004
    Cheyenne, WY
    MVPA
    31099
    Posts
    7,379
    Thanks
    977
    Default
    Quote Originally Posted by jeffhuey1n View Post
    Just sandblast them.
    1951 Willys M38
  8. #27
    Join Date
    Mar 2010
    Posts
    1,150
    Thanks
    847
    Default
    Quote Originally Posted by hndrsonj View Post
    . Yup, I plan on it. That bumper won’t fit in the cabinet
    1 each M1009
    USMC/USAF
  9. #28
    Join Date
    May 2004
    Cheyenne, WY
    MVPA
    31099
    Posts
    7,379
    Thanks
    977
    Default
    If you need one just ask!
    1951 Willys M38
  10. #29
    Join Date
    Mar 2010
    Posts
    1,150
    Thanks
    847
    Default
    Once things dry out a bit, I’ll pull it out of the barn and give it an intense scrub down. Got 70+ years of accumulated crap to scrape off. I definitely could use a sand blaster for outside use.
    1 each M1009
    USMC/USAF
  11. #30
    Join Date
    Mar 2010
    Posts
    1,150
    Thanks
    847
    Default
    Front bumper is almost finished with repairs. One last piece of metal to get rid of. Then paint and prep for installation.
    1 each M1009
    USMC/USAF
Similar Threads
  1. G506 radiator?
    By racerlee in forum CCKW
    Last Post: 06-30-2013, 23:54
  2. G506 questions
    By moose97 in forum CCKW
    Last Post: 01-09-2013, 22:58
  3. 44 G506 value
    By johnnylazer in forum CCKW
    Last Post: 02-12-2010, 17:51
  4. new g506 toy
    By woodwalker in forum CCKW
    Last Post: 11-01-2009, 12:02
  5. My new G506?
    By DMgunn in forum CCKW
    Last Post: 07-21-2009, 23:54
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
