Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Best way to wire up a RAK15 ration heater?
  1. #21
    Private AttackMule's Avatar
    Join Date
    Jul 2016
    KC MO
    Posts
    11
    Thanks
    Default
    I bought 2 cables from Cole Parmer they still have them in stock!! I will have to get into my emails; have the drawings for both plans.
    Two types: one has the straight plug the more expensive one has the 90.
  2. The Following User Says Thank You to AttackMule For This Useful Post:
    Rusty Loads (12-14-2018)
  3. #22
    Corporal
    Join Date
    Sep 2011
    Ontario, Canada
    Posts
    47
    Thanks
    Default
    I think one of my trucks has the 3 pin outlet; my Zeppelin shelter has them I'm almost sure. The ones from Cole-Parmer show a 3 pin to 2 pin and other variations...I will need to confirm what I've got but finding the hot wire is a good start. Wasn't that one cable mentioned over $300.00USD!!! special military price! Thanks for info.
    1985 Tatra T 815 VTI 8x8
    Zeppelin FM2 Radio Box
    M973 Hagglunds BV206
    Mess of Unimogs
    MB Gwagen
  4. #23
    Just a Grunt Storm 51's Avatar
    Join Date
    Jan 2012
    Seattle, WA
    Posts
    880
    Thanks
    444
    Default
    The A pin is 24+ VDC. The B pin is ground the C pin is unused.
    Wm Perry has the connectors (I believe the part number was given earlier in this thread, if not I can post it this weekend). It is easy to make your cable(s), which allows you to customize the length to your needs. Unless the new cables are less than $20 to $30 dollars, it is better to make your own, IMO.
    The cable is either 14-3 or 14-2 (your choice) that you can get at any hardware store.
    Good Luck with your project!
    1952 M-37 / M-42
    1967 M101A1
    3 M-37 Parts Trucks
    Lots of Accumulated M-37, M-42 & M-43 Accessories & Parts
  5. The Following User Says Thank You to Storm 51 For This Useful Post:
  6. #24
    Join Date
    Jul 2016
    KC MO
    Posts
    11
    Thanks
    Default
    Following are answers to questions i had about the cables used to power RAK15 and a POC for the cables. They will make them for you; they are not cheap; they are of great quality. i have two and connected them to surplus NATO single pin connectors. I hope to post the pdf drawings later:
    1) There is a possible option for a lead we could supply (AZ9121). It has a right angled connector on one end and is unterminated on the other, you can then attached his plug of choice to it. The attached drawing clearly identifies +ve and -ve DC. However this is a custom made-to-order cable so would have a long -lead time and we would have to price up accordingly so would be a more expensive option.
    2) So the cheaper and easier option would be to supply our standard AZ9224 (stock item with 4 week lead time) and just remove one end socket to provide the connector end but then the flexible option you need.
    a. We can either quote you for the standard cable and let you cut one socket off, or we can cut it off here and cost up for the cable and additional manual work.
    Some points to be aware with regard to the RAK unit use that you may or may not be aware of at this time.
    1) RAK units do not have internal over-current protection (i.e. they don’t have a fuse in them.) so over-current protection must be achieved externally.
    2) Typically our customers achieve this using the vehicles fuse box and a designated socket for the RAK, but it could also be a fuse in the plug, or an inline fuse in the cable.
    3) The RAK15 draws a nominal current of approximately 15amps, so the fuse should be rated a little bit higher than this to provide adequate protection but to avoid blowing the fuse during normal protection.
    o The RAK30 draws a nominal current of approximately 30amps, same advise applies with regard to fuse rating above this level.
    Best regards
    Simon
    Simon Cook
    United Kingdom & Ireland, Northern & Eastern Europe Sales Manager
    Bibby Scientific Limited
    Stuart - Techne - Jenway – Electrothermal - PCRmax
    Beacon Road, Stone, Staffordshire, ST15 0SA.
    m: +44 (0)7798 651411
    e: Simon.Cook@bibby-scientific.com
    w: www.bibby-scientific.com
  7. The Following User Says Thank You to AttackMule For This Useful Post:
    Rusty Loads (01-01-2019)
  8. #25
    Corporal
    Join Date
    Sep 2011
    Ontario, Canada
    Posts
    47
    Thanks
    Default
    Thanks for posting that. I'm slowly learning about these connectors.
    Mess of Unimogs
    MB Gwagen
  9. #26
    Join Date
    Jul 2016
    KC MO
    Posts
    11
    Thanks
    Default
    Quote Originally Posted by Rusty Loads View Post
    I have two sets of plans for the cables—one for the 90 and one for the straight connector. They are in pdf and i can’t figure how to post them.
    here is a great link to their website; includes part numbers and manual downloads
    http://www.electrothermal.com/admini..._SEPT16(1).pdf
    i have posted 2 pics of the plans now i hope they appeared ; can some tell me how to post pdf?
    Attached Images Attached Images
  10. #27
    Join Date
    Jan 2012
    Seattle, WA
    Posts
    880
    Thanks
    444
    Default
    They are visible on the site in the thread.
    Thanks, those are nice to have!
    1952 M-37 / M-42
    1967 M101A1
    3 M-37 Parts Trucks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
