Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: CUCV Ham radio antenna bracket
  1. #11
    Colonel Abbylind's Avatar
    Join Date
    Dec 2011
    Tijeras/NM
    Posts
    251
    14
    Default
    What band is that? Looks like a discone...
    No plants were harmed making this post however several free electrons were horribly inconvienced ....
    Remember when someone says they are an "EXPERT"... an "EX" is a "has been" and a "SPERT" is a "little drip!"...
  2. #12
    2 Star General Mainsail's Avatar
    Join Date
    Feb 2012
    Puget Sound, WA
    Posts
    799
    144
    Default
    Here's the link: http://www.universal-radio.com/catal...antm/6458.html
    Wide band coverage: 144-164, 380-520 and 696-870 MHz
    I added the radials; the manufacturer suggests that for fixed mounting you bend the radials down at 70 degrees, and even though this is a mobile application, the riser makes it act like a base antenna. That's my theory anyway.
    The contacts I've made on 2 meters and 70cm all said I sound good but I haven't put a meter to it yet to see what the SWR is like. One of the ham club guys tried to connect his bridge SWR meter to it but the high power of the radio released the magic smoke from within it. Reception seems as good to only slightly less than what I was getting with the big dual band antenna.
    The angle of radiation seems lower on this antenna than on the whip. I have a go-light on the opposite side that gets wonky when I key up on VHF with the big dual band, but doesn't with the compactenna. That could be because it isn't getting the power out or because the radiation angle is lower (or because the antenna is shorter).
    Anyway, it serves a purpose being shorter and less likely to get bent over like the tall whip.
    THIS IS CHARLESTON COMMAND POST WITH A DEFINITE PURPOSE LAUNCH DIRECTIVE; ALL CREWS REPORT “READY TO TAXI”.
  3. The Following User Says Thank You to Mainsail For This Useful Post:
    SgtHaas (05-27-2016)
  4. #13
    Join Date
    Dec 2011
    Tijeras/NM
    Posts
    251
    14
    Default
    Sounds interesting. You could put a MFJ 269c analyzer on it and see what the SWR is on the different bands (no 800)
  5. #14
    Moderator antennaclimber's Avatar
    Join Date
    Jun 2008
    State College, PA
    MVPA
    31818
    Posts
    935
    313
    Default
    My M1009 set up.
    Attached Images Attached Images
    1991 M925A2
    1986 M1008
    1986 M1009 USN
    1985 M1010
  6. The Following User Says Thank You to antennaclimber For This Useful Post:
    SgtHaas (05-28-2016)
  7. #15
    4 Star General DJones's Avatar
    Join Date
    May 2010
    New Palestine Indiana
    Posts
    1,051
    2,839
    Default
    Quote Originally Posted by antennaclimber View Post
    My M1009 set up.
    That's a nice looking interior on your truck.
  8. The Following User Says Thank You to DJones For This Useful Post:
    antennaclimber (05-29-2016)
  9. #16
    Join Date
    Jun 2008
    State College, PA
    MVPA
    31818
    Posts
    935
    313
    Default
    Updated photos.
    1991 M925A2
    1986 M1008
    1986 M1009 USN
    1985 M1010
  10. The Following 2 Users Say Thank You to antennaclimber For This Useful Post:
    DJones (05-30-2016), Mainsail (05-30-2016)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
