Results 1 to 6 of 6
Thread: Solo Tire Mounting The Easy Way
  1. #1
    4 Star General aleigh's Avatar
    Join Date
    Jun 2013
    Phoenix, AZ & Seattle, WA
    Posts
    1,016
    Thanks
    208
    Default Solo Tire Mounting The Easy Way
    So I was mounting up another 395/85R20 for my LMTV, and I was doing it alone. The bead was stuck pretty good and I don't own a bead breaker. Yes, there are lots of tricks - sledges, tire irons, soap and water, swearing. Well this is what I came up with. This is a cheater method and if you have a forklift I honestly can't think of an easier way other than paying someone else to do it. I think it is faster even than using a breaker.
    Skip to the pictures: https://www.flickr.com/photos/advent...57671249646726
    1. Spread forklift tines far enough that the forklift only supports the rubber.
    2. Pull any CTIS stuff and all the nuts off using an impact gun.
    3. Put the tire on the forklift lugnut side down.
    4. Run a recovery strap or chain to something immovable. I have a stacker so I used the outriggers. You could probably park a lift truck on the strap too.
    5. Attach the strap to the wheel half. Just go through the lugnut holes.
    6. Lift the tire. The small half just pops off.
    7. Flip the wheel.
    8. Repeat with the large half of the wheel. Put the straps around the lugs.
    9. Unbolt and remove the bead locker. Lower the tire, stand in it, and kick the ring into the tire so you can get to the bolts. It "unscrews" from the tire.
    10. Discard old tire
    11. Place new tire on forklift.
    12. Install beadlocker
    13. Drop in large wheel half. Lower tire and jump on it if required. Be aware of valve alignment and it may catch on the bolts of the bead locker.
    14. Raise tire.
    15. Place small wheel half on something - bucket, crate, whatever you have.
    16. Lower tire. Align bolts with holes in small half. Lower bolts through.
    17. Reach underneath lift and thread on a couple of bolts.
    18. Raise tire. Run impact gun on all the nuts in the correct pattern.
    19. Install CTIS stuff. Air up.
    20. Done
    * Notes
    I like to clean the rim up, particularly if it is marred from tire irons with a random orbital sander. If your o-ring falls out and won't stay upside down you can either clean it up and put it on the small half or you can flip the tire an additional time.
    M1078, M1082, M101A1, M103A3
    KE7MSY - https://www.flickr.com/photos/adventioneering/
  2. #2
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,352
    Thanks
    2,401
    Default
    Wow, that tire was wasted! Those pallet stackers sure are handy aren't they?! Nice job.
  3. #3
    Modertator swbradley1's Avatar
    Join Date
    Jan 2008
    Dayton, OH
    Posts
    13,687
    Thanks
    3,888
    Default
    Nah, little ArmorAll buff it right out.
    sw
    Yes, that's an image of my skull.
  4. #4
    Sergeant Major
    Join Date
    Feb 2014
    Columbus, Ohio
    Posts
    180
    Thanks
    13
    Default
    Thanks for posting the tip, I used it yesterday to breakdown 2 tires to replace the valve stems. Worked great!!
  5. The Following 2 Users Say Thank You to Smike740 For This Useful Post:
    aleigh (07-30-2016), Karl kostman (11-08-2018)
  6. #5
    4 Star General coachgeo's Avatar
    Join Date
    Nov 2010
    North of Cincy OH
    Posts
    2,225
    Thanks
    734
    Default
    Quote Originally Posted by aleigh View Post
    So I was mounting up another 395/85R20 for my LMTV, and I was doing it alone.... This is a cheater method and if you have a forklift I honestly can't think of an easier way other than paying someone else to do it. I think it is faster even than using a breaker.
    Skip to the pictures: https://www.flickr.com/photos/advent...57671249646726...
    Please up load pics to this board so they get archived in here.
    One does not get troubles in life... just character building opportunities. Build on with a smile
    Moderator: Orange Tractor Talks & AmbulanceRV
    Daily driver- 99 VW TDI or 2002 KLR DIESEL w/cvt... weather permitting
    Projects: 96 M1078, 97 Triumph Tiger w/3cyl Diesel Kubota
    Sold: 1962 Dieselized Unimog 404, 1984 Int. 24foot Flatbed, 97 Jeep TJ heavily Modified, Datsun Roadster(s) & 510(s)
  7. The Following User Says Thank You to coachgeo For This Useful Post:
    frank8003 (11-08-2018)
  8. #6
    4 Star General snowtrac nome's Avatar
    Join Date
    Nov 2016
    western alaska
    Posts
    1,457
    Thanks
    Default
    I had my rr mvt do the same thing a couple weeks ago
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
