Results 1 to 2 of 2
Thread: M1078 Paint
  1. #1
    Private
    Join Date
    Nov 2016
    crivitz, wi
    Posts
    10
    Thanks
    Default M1078 Paint
    Our fire department obtained an M1078 to be used as a brush truck. We want to paint the cab red and put our logo's on the doors. I know nothing about the paint. Can we simply sand it, apply a primer, then paint over the primer. If so, what type of paint and primer should we use. Is the current camo paint toxic. Can we sand it using a simple face mask outside, or do we need to wear breathing apparatus while sanding. Thanks. Dave.
  2. #2
    4 Star General snowtrac nome's Avatar
    Join Date
    Nov 2016
    western alaska
    Posts
    1,549
    Thanks
    Default
    I'm no body man ,the chemical agent resistive coating AKA CARC is essentially imron paint it is tough as nails, and ppe precautions are the same as you would use for imron. Be advised dust masks are for convenience, any time a mask is required, it must be FIT tested to an assigned user, and said user must have a medical clearance to use one. just have your body shop use the same procedure's they would use with poly urethane or imron paint.
  3. The Following User Says Thank You to snowtrac nome For This Useful Post:
    TNriverjet (12-23-2016)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
