Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: M750 van trailer
  1. #21
    LLM/Member 785 Recovry4x4's Avatar
    Join Date
    Jun 2004
    Posts
    33,373
    Thanks
    755
    Default
    Phil, not sure what you have there with those numbers but if it looks like the ones pictured above, I doubt you could get the tongue under 6000#. If it has the 5 load banks like mine used to have, add another 1000# to that total. I'd say moving a semi trailer with a pickup, might get you noticed.
    1986 M1008
    1984 M1031
    1984 M1010
  2. The Following User Says Thank You to Recovry4x4 For This Useful Post:
    Floridianson (04-02-2018)
  3. #22
    General 4XDesign's Avatar
    Join Date
    Nov 2011
    Blythewood, SOUTH CAROLINA
    Posts
    401
    Thanks
    96
    Default
    I found a m750 chassis for sale. I'm unable to find specs on it. If any one has one available to measure. I'd like to know the length over fifth wheel from step up to the front. Also the king pin to front end, the frame length from step down to rear and height at step up and step down. Sorry I know it's a lot... thanks for any help
    Instagram #toughcustomsgarage
  4. #23
    General
    Join Date
    Jul 2006
    Southern, Maryland
    Posts
    435
    Thanks
    Default
    The M750 trailer and the M447 trailers are M295 semi-trailer chassis with different boxes mounted. It is too cold and dark outside to take pictures of either my M750 or M447 trailers. However, I did find this picture of a data plate online.
  5. #24
    Join Date
    Nov 2011
    Posts
    401
    Thanks
    96
    Default
    Quote Originally Posted by Scrounger View Post
    Okay great thank you that's enough info for me to know my idea will not work on
    that chassis.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
