Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: MRAP parts identification
  1. #21
    Corporal
    Join Date
    Jul 2017
    Mustang,Oklahoma
    Posts
    26
    Default
    Another update to this brake issue. I'm getting the part #'s for some commercial brake chambers. The BAE requirement on the park brake system was to hold truck at a 30 degree incline. So when theres a fluctuation in air pressure the brakes come on. As LE we don't need that heavy of a park spring in these units we don't have all the exterior added on reactive armor. I'm getting the part # on these and will share this info as soon as I have it. I've also got a copy of the Meritor Maintenance procedures manual and Meritor Parts manual. As soon as I have these #'s I will order all the parts and update with my results.
  2. The Following User Says Thank You to Oklahomadeputy For This Useful Post:
    silverstate55 (07-22-2017)
  3. #22
    Corporal
    Join Date
    Jul 2017
    Mustang,Oklahoma
    Posts
    26
    Default
    Alright here is an update. The commercially available brake Chamber part #'s are Meritor D63-3276X24 or MGM brand MJB2430ET756. These will require a little plumbing work because they have zero degree offset on fittings. The BAE required 30 degree offset. So there might have to be some fittings installed. I will be trying to make a video of the process when I get all the parts in and get started on the repair. Also you will need KIT7186 to have all the necessary seals and bearings etc.. to do the job. I also have the above mentioned manuals, s if you need them send me a message with an email address and I will get them to you.
  4. The Following 3 Users Say Thank You to Oklahomadeputy For This Useful Post:
    gimpyrobb (10-25-2017), silverstate55 (07-22-2017), SWATCOP819 (01-30-2018)
  5. #23
    Corporal
    Join Date
    Jul 2017
    Mustang,Oklahoma
    Posts
    26
    Default
    Well my order is in and waiting on parts. If you don't need to replace the bearings you can order KIT7188 and that will be seals only. The brake calipers are still Mil-Spec and the pads are also. The rotors are still same mil-spec, the only thing that isn't is the Brake Chambers which will be commercial spec to lose the heavy park spring. After speaking to the Contact at Meritor they are getting more of these part #'s cleared off the Govt only side. He verified they are in stock and available and put me in touch with my Local Meritor District MGR to get the parts in a timely manner. He did say order your seal kits separate because they are experiencing a backorder issue on those. They are boosting the production order but its still taking time. Also there is a Special Tool needed to pull the Hub Nut behind the planetary, so touch base with a local armory repair center or a base in your area about assisting with repair, or loaning you the tool kit.
  6. The Following User Says Thank You to Oklahomadeputy For This Useful Post:
    silverstate55 (07-28-2017)
  7. #24
    3 Star General
    Join Date
    Oct 2015
    Texas
    Posts
    827
    12
    Default
    Flame enterprises has brake pad sets part number KIT2252L2DAM nsn 2530-01-598-0011
    http://www.flamecorp.com/
    Present
    2008 M1078A1 W/W
    2006 M1078A1
    2006 M1078A1
    2005 M1078A1
    2005 M1084A1 W/MHE
    1998 M1078
    1998 M1078 W/W
    1995 M1078
    1987 FLU419
    Gone but not forgotten
    1998 M1088 for parts
    2003 M1078A1 W/W for parts
    1994 M1078
    2003 M1078A1
  8. The Following User Says Thank You to scottmandu For This Useful Post:
    silverstate55 (07-25-2018)
  9. #25
    Private Steel Soldiers Vendor
    Join Date
    Oct 2017
    Kansas City, MO
    Posts
    Default
    We have 140 new BAE Caiman chassis and a yard full of new, unused BAE Caiman II parts. Located in Dallas.
  10. #26
    Join Date
    Oct 2017
    Kansas City, MO
    Posts
    Default
    BAE Caimans and Caiman parts at www.caimanchassis.com.
  11. The Following User Says Thank You to Midway For This Useful Post:
  12. #27
    Private
    Join Date
    Jul 2018
    macclenny/ FL
    Posts
    Default
    Anyone able to point me in the right Direction? Our agency has a Caiman ...... started having electrical issues ..... Fried the inverter on the outside close to the firewall (inverter was smoking every time we started it and Guages bouncing .. 12v and 24v side)
    we have the new inverter, but im scared to install it and fry the new one
  13. #28
    Join Date
    Oct 2017
    Kansas City, MO
    Posts
    Default
    Here's an email reply I got from someone whose company works on LMTV's which are similar mechanically.
    It could be any number of things…bad ground, bad alternator, bad regulator, bad LBCD…no way to tell without full diagnosis.
  14. #29
    Corporal
    Join Date
    Jul 2017
    Mustang,Oklahoma
    Posts
    26
    Default
    Midway
    Can you give me your contact information
    Mizej@ccsheriff.net
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
