Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Generator Accessories
  1. #1
    2 Star Admiral Daybreak's Avatar
    Join Date
    Mar 2015
    Northern, Virginia
    Posts
    1,266
    Thanks
    210
    Default Generator Accessories
    Howdy,
    slide hammer
    slide rod driver/puller rod
    5120-01-013-1676 SLIDE HAMMER, GROUND 13226E7741
    ground rod, knuckles, ground strap, drive head bolt
    5975-00-878-3791 RODS, GROUND SECTIONAL 9FT AA-55804-III-B
    5975-00-794-2523 COUPLINGS, (THREE IN SET)
    5975-00-924-9927 DRIVE/HEAD STUD
    remote 55gal/5gal fuel pickup adapter
    2910-00-066-1235 ADAPTER ASSY, FUEL DRUM 13211E7541
    7240-01-337-5269 FUEL CAN, OLIVE DRAB
    7240-00-177-6154 FLEXIBLE SPOUT
    aux fuel supply line
    4720-00-021-3320 or 4720-01-469-7057 HOSE ASSEMBLY, NONMETALLIC
    Oil drain elbow
    4730-00-809-9703 ELBOW, PIPE TO HOSE MS24519-9
    trailer grounding stud
    5940-00-021-3321 GROUND TERMINAL STUD MS39347-2
    6awg braided copper ground
    carbon dioxide fire extinguisher
    4210-01-361-6921 Fire Extinguisher, CO2
    Hammer
    5120-00-251-4489 Sledge Hammer, 8lbs.
    Trailer Mounted Accessories Box
    ~~Later Mike
  2. The Following 11 Users Say Thank You to Daybreak For This Useful Post:
    boxer4luvr (08-13-2018), Buddy1 (12-14-2017), CUCV_ut (09-26-2018), dav5 (08-25-2017), Guyfang (08-28-2017), lindsey97 (10-17-2017), m32825 (10-01-2017), Ridgerunr (10-18-2019), robson1015 (08-26-2017), Sgt Jiggins (06-25-2019), steelydan (09-19-2017)
  3. #2
    General
    Join Date
    Nov 2016
    South Hampton Roads, Virginia
    Posts
    575
    Thanks
    416
    Default
    I bought one of the generator trailers out of Letterkenny recently and was surprised to discover a box of tools was included. This worked well for me because I haven't received anything except 1 aux. fuel line with the 2 generators I've purchased. The tool box had just about everything except an auxiliary fuel line. There was a bag of fittings that included bolts for bolting generator to trailer, tool box to trailer, the ground stud, and 2 oil drains - 1/2" and 3/4" pipe - with hose and clamps. Also had an 8 lb sledge hammer and ground rod kit (rods, slide hammer, bolts/nuts) in it. A VERY nice surprise!!!
    Attached Images Attached Images
  4. The Following 2 Users Say Thank You to Zed254 For This Useful Post:
    CUCV_ut (09-26-2018), Guyfang (08-28-2017)
  5. #3
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    6,259
    Thanks
    12,079
    Default
    Pictures speak louder than words!
  6. The Following User Says Thank You to Guyfang For This Useful Post:
    Daybreak (08-28-2017)
  7. #4
    Corporal
    Join Date
    Apr 2016
    Sussex County, NJ
    Posts
    37
    Thanks
    22
    Default
    Quote Originally Posted by Zed254 View Post
    I have to ask... What kind of covers did you make for the air intake grates. I'm currently wrapping mine up in a tarp, not sure if it keep moisture out or in. So far I removed one mouse nest and afraid there are more coming.
    Thanks,
    Erik
    Sent from my XT1254 using Tapatalk
  8. #5
    Join Date
    Mar 2015
    Northern, Virginia
    Posts
    1,266
    Thanks
    210
    Default
    Quote Originally Posted by Grizzlypower2001 View Post
    Thanks,
    Erik
    Howdy,
    The thread is about generator accessories.
    Zed talk's about that here. https://www.steelsoldiers.com/showth...t=#post2002338
    ~~Later Mike
  9. The Following User Says Thank You to Daybreak For This Useful Post:
    Grizzlypower2001 (08-29-2017)
  10. #6
    General
    Join Date
    Nov 2016
    Posts
    575
    Thanks
    416
    Last edited by Zed254; 08-29-2017 at 08:16. Reason: Moved to "Do You Cover Your 803" thread
  11. #7
    3 Star General
    Join Date
    Mar 2013
    Oregon
    Posts
    958
    Thanks
    631
    Default
    Got any part #'s for the plastic Box Wrenches used on load terminals and which model genset load terminals they can be used on? I have looked in TM's but can't seem to put my finger on Box Wrench p/n for MEP-002a/-003a.
    GEN #1 House Gen PU-751/M: 1986 MEP-002a/M116A2 w/Aux Tank & OEM cover
    GEN #2 Spare Gen PU-751/M: 1991 MEP-002a/M116A2 w/Aux Tank & OEM cover
    GEN #3 Shop/Barn Gen NF-2 Enclosure: 19XX MEP-002a w/Aux Tank
    GEN #4 Spare Gen PU-751/M: 1991 MEP-002a/M116A2 (a work in process)
    * Disclaimer - My comments on this forum are based on my opinion and my experiences only. It is your responsibility to verify any information before using or to hire a professional.
  12. #8
    Join Date
    Dec 2015
    Posts
    6,259
    Thanks
    12,079
    Default
    Chainbreaker,
    There never was any box wrench made for any MEP-002A to 007A.
  13. The Following User Says Thank You to Guyfang For This Useful Post:
    Chainbreaker (09-07-2017)
  14. #9
    3 Star General
    Join Date
    Mar 2013
    Oregon
    Posts
    958
    Thanks
    631
    Default
    Quote Originally Posted by Guyfang View Post
    Chainbreaker,
    Hmmm, I see box wrenches advertised from time to time on eBay that "allegedly" are supposed to fit -002A/-003A load terminals. I once bought one of those that seller advertised to fit -002a; unfortunately it was a big honker that did not fit (P/N: CTM-282 / 5120-00-138-3790). Well...I guess if they never made a box wrench to fit the -002a/-003a load terminals I should just stop looking and use a metal one.
  15. #10
    General
    Join Date
    Nov 2016
    Posts
    575
    Thanks
    416
    Default
    An image of the wrench from my MEP-803A is attached for part numbers. A 1-3/8 combination wrench fits the lugs. No idea if it will fit an 002a/003a. Part number is 30554 88-21146.
  16. The Following 2 Users Say Thank You to Zed254 For This Useful Post:
    boxer4luvr (08-13-2018), Chainbreaker (09-07-2017)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
