Generator Accessories
Daybreak
2 Star Admiral
740
Va
Howdy,
slide hammer
slide rod driver/puller rod
5120-01-013-1676 SLIDE HAMMER, GROUND 13226E7741
ground rod, knuckles, ground strap, drive head bolt
5975-00-878-3791 RODS, GROUND SECTIONAL 9FT AA-55804-III-B
5975-00-794-2523 COUPLINGS, (THREE IN SET)
5975-00-924-9927 DRIVE/HEAD STUD
remote 55gal/5gal fuel pickup adapter
2910-00-066-1235 ADAPTER ASSY, FUEL DRUM 13211E7541
7240-01-337-5269 FUEL CAN, OLIVE DRAB
7240-00-177-6154 FLEXIBLE SPOUT
aux fuel supply line
4720-00-021-3320 or 4720-01-469-7057 HOSE ASSEMBLY, NONMETALLIC
Oil drain elbow
4730-00-809-9703 ELBOW, PIPE TO HOSE MS24519-9
trailer grounding stud
5940-00-021-3321 GROUND TERMINAL STUD MS39347-2
6awg braided copper ground
carbon dioxide fire extinguisher
4210-01-361-6921 Fire Extinguisher, CO2
Hammer
5120-00-251-4489 Sledge Hammer, 8lbs.
Trailer Mounted Accessories Box
Zed254
465
S. Hampton Roads, VA
I bought one of the generator trailers out of Letterkenny recently and was surprised to discover a box of tools was included. This worked well for me because I haven't received anything except 1 aux. fuel line with the 2 generators I've purchased. The tool box had just about everything except an auxiliary fuel line. There was a bag of fittings that included bolts for bolting generator to trailer, tool box to trailer, the ground stud, and 2 oil drains - 1/2" and 3/4" pipe - with hose and clamps. Also had an 8 lb sledge hammer and ground rod kit (rods, slide hammer, bolts/nuts) in it. A VERY nice surprise!!!
Sussex County, NJ
I have to ask... What kind of covers did you make for the air intake grates. I'm currently wrapping mine up in a tarp, not sure if it keep moisture out or in. So far I removed one mouse nest and afraid there are more coming.
Thanks,
Erik
Sent from my XT1254 using Tapatalk
Daybreak
2 Star Admiral
740
Va
Chainbreaker
1,833
Oregon
Got any part #'s for the plastic Box Wrenches used on load terminals and which model genset load terminals they can be used on? I have looked in TM's but can't seem to put my finger on Box Wrench p/n for MEP-002a/-003a.
Chainbreaker
1,833
Oregon
Chainbreaker,
There never was any box wrench made for any MEP-002A to 007A.
Hmmm, I see box wrenches advertised from time to time on eBay that "allegedly" are supposed to fit -002A/-003A load terminals. I once bought one of those that seller advertised to fit -002a; unfortunately it was a big honker that did not fit (P/N: CTM-282 / 5120-00-138-3790). Well...I guess if they never made a box wrench to fit the -002a/-003a load terminals I should just stop looking and use a metal one.
Zed254
465
An image of the wrench from my MEP-803A is attached for part numbers. A 1-3/8 combination wrench fits the lugs. No idea if it will fit an 002a/003a. Part number is 30554 88-21146.
Guyfang
22,087
Burgkunstadt, Germany
I didn't say that some of the wrenches won't fit. I said the milatary didn't make one especially for the 002 & 003. Now if I wanted to really know, I would look at the NSN of the load terminal, in several different parts manuals, and compare that to the various TQG parts manuals. I might just do that when I am using my computer, and not this silly tablet.
Light in the Dark
5,112
MA
I think the wrench for the 802/803 works just fine on the 002/003 (I think I have used this many times on the 002 I just sold).
reset2
60
Myersville MD
I just won an 803 at Letterkenny but it only came with a terminal wrench trailer jack crank and 3 ground rod sections.
Sent from my SM-G935V using Tapatalk
DOGWOODRIDGE
jackson, la
I’m looking for the housing cover that goes over the cylinders on my MEP-002 generator. It came without one. Anyone know where I might find one?
Guyfang
22,087
Send a PM to Ray 70, and start a Want Add in the Parts wanted forum. When you post something to an old thread, often you do not get the visibility you need.
glcaines
2,399
Hiawassee, Georgia
I don't know if they have them now or not, but I got a different replacement part of the enclosure for my MEP003A from Delks several years ago. The price was very good at the time.
