Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 37 of 37
Thread: First MUTT
  1. #31
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    33
    Thanks
    Default
    Almost forgot. This Mutt is showing her colors which I find unique as the original semi gloss OD is coming through then the MERDC, and finally what I believe is the 383 CARC green. I was kicking around a paint job however the history of service surfacing seems too awesome to cover. Thinking of just touching up the rust here and there and maybe new stencils. Would like to uncover some original unit markings however unmatched they may be for the bumpers and hoods were changed like underwear I'm sure haha. I'll post some pics of the paint.
  2. #32
  3. #33
  4. #34
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    33
    Thanks
    Default
    So after My compression testing I discovered two head gasket leaks and two exhaust leaks. Took head to local engine shop with literature pulled from TM's. Shop has been in business for 30+ years. The two lower mount bolts for the intake manifold were missing. Threads appeared to be shot. One hole shot on the exhaust manifold bolts and I snapped another. Just waiting for the head to return. In the mean time I am going to clean up the deck, Remove the radiator... speaking of the rad, the two lower mounting bolts have spun free not allowing the lock nuts to be removed easily so once it is removed it is being sent out for a refurb.
  5. #35
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    33
    Thanks
    Default
    It turns out I have an early style head on my engine. Thanks goes out to rickf and the members of G838 forum for helping me identify some parts. Not too sure what the key differences in the head are though?
  6. #36
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    33
    Thanks
    Default
    Well the head is done. Checked out great and had a valve job done. One of the exhaust valve boss's threads are jacked but the head itself is fine. Just need to thread a bolt through. Dropped the Rad off at a local shop to get cleaned up and I am in the process of ordering new gaskets, rubber mounts, Rad bolts, set of belts and other misc parts. Will post pics when I'm done with my shift.
  7. #37
    4 Star General Another Ahab's Avatar
    Join Date
    Jan 2012
    Alexandria, VA
    Posts
    14,945
    Thanks
    21,625
    Default
    Late to the "party".
    But all in:
    - Subscribed
    M35A2 w/Winch SOLD
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
