- 15,866
- 22,068
- 113
- Burgkunstadt, Germany
Morning sleepy heads!
I am working on, (if I don't go insane first) improving the wire diagrams for the MEP-802A and Mep-803A generators. Sadly, I don't have one, to run out to and look at, when I have a stupid question. I have already found one mistake. The manuals have crappy wire diagrams. The form is good, but the quality is crappy. Soooooooooo, I figured I might be able to improve things.
I need someone to look, the next time they stick their nose into the control panel, at the ground points. The is a ground point on the control panel door, with a couple wires on it. I need to know the wire numbers.
I also need the wire numbers on the Control Panel Ground Point. It's in the back of the control panel box. There may also be another ground point there. I KNOW there is one for the A1, volt regulator, where the coax shields for two wires 156A and 157B are grounded. I THINK there are several other wires grounded there, but am not sure.
So would one of you big strong men take a gander for me? I may have other requests, but am on the verge of losing my mind doing this. So we will take it a step at a time.
Take care and have a wonderful day!! In any case better then the rain and snow we have had of late. I hate winter!
Guy
Guy
