Hemtt wheels and CTIS on an M923a2
Vintage iron
14
Falmouth Ma.
in that case. I made an aluminum spacer block to space out the stock CTIS valve out and built new valve mounting plates. I used the longer CTIS hoses that are used on the rear axles to give me more flex in the hoses.
Flatlander
Lubbock, Texas
I have been building and customizing military trucks full time for about ten years now, most of you are familiar with my work as A&H Recon shop. over the years I have converted a bunch of 5 ton trucks to 1600s. This is what I found. Since M939A2 series trucks have out bound drums you don't need HEMTT rims on the front.
Ok, so stock rims can be used on the a2s...but aren’t there rubbing issues since the backspacing is more to the center of the truck vs the HEMTT rims?
Flatlander
Lubbock, Texas
I have put 1600s with stock 5 ton rims on the front of an A2 with No rubbing. the outbound drums make all the difference.
Well, great! I like the sound of that. Can you explain the difference in the drums from the a1/a2? I didn’t realize there was a difference other than ctis and hub seal design. Are the drums mounting surfaces different?
