Hammer
- 387
- 83
- Winlock, WA
Well, after working over the truck and driving it some, I found a few quirks.
First thing, the dash lights work when I pull the light switch out to the running lights position.
But when I pull it all the way out to turn the headlights on, all the dash lights go off. Even the shifter lights.
Also, it doesn't dim the dash lights when they work. Wasn't sure if this switch did the dimming function or not.
I swapped the tires out to the 16r20 Michelin tires. Now I need to correct the speedo.
Is there a known adapter for this?
And where do a find a key to open it?
The headlight dimmer switch is not doing well. Anything special about these? Or will any standard floor switch work?
My voltage gauge drops voltage fast when I turn anything on in the cab.
This kind of sounds like bad grounds, or something other than a large drop in voltage. Just one dash fan drops the voltage by over a half volt.
What is the fuel button supposed to be for about 400 HP?
My truck does NOT feel like it is even close.
All of my heater controls are stuck except the fresh/recirculate.
I think the fan motor is seized up, but I haven't pulled that apart yet.
Are all the cables generic that push pull the controls? They look like it.
My PTO light on the dash doesn't always work.
My PTO cable is bent, so it will engage the PTO, but not disengage. I have to climb under it to manually disengage.
The PTO light works sometimes and not others. The wiring looks fine, etc.
Is it a pressure switch, or a mechanical switch?
