Page 18 of 18 FirstFirst ... 8 14 15 16 17 18
Results 171 to 175 of 175
Thread: AcuTemp Refrigerator
  1. #171
    Private
    Join Date
    Aug 2017
    Catonsville, MD
    Posts
    11
    Thanks
    Default
    Is there a cable ... possibly a slave cable that connects to passenger side battery slave recepticle ... that is used to connect to HMMWV? I'd want to use this while camping with my HMMWV. Imagine hunting, field dress, and immediate storage without heading home...WOW! If you or anybody else can id a cable that I could use to connect the refrigerator to HMMWV, it will be greatly appreciate. I don't dare pull the trigger on refrigerator until I know how to connect it Thanks!!
  2. #172
    4 Star General
    Join Date
    Mar 2014
    Efland, NC
    Posts
    1,837
    Thanks
    461
    Default
    Quote Originally Posted by kromane View Post
    You can power the unit from 12-28V DC. There is a connector for that. Make sure you get the cable. I power mine in the field from either solar panels or from the trailer plug on the back of my truck. Works great.
    Chris Medico
    MEP-003a (sold), MEP-803a, MEP-802a, & MEP-831a
  3. #173
    4 Star General Steel Soldiers Vendor Suprman's Avatar
    Join Date
    Feb 2013
    Stratford/Connecticut
    Posts
    6,573
    Thanks
    31
    Default
    Just wire the dc power cable to a slave connector
  4. The Following User Says Thank You to Suprman For This Useful Post:
    kromane (11-13-2019)
  5. #174
    Private
    Join Date
    Aug 2017
    Catonsville, MD
    Posts
    11
    Thanks
    Default
    Thanks! Cable is key. HMMWV is 24v. If I can determine cable and connections, then I can seriously consider one of these. Afteer reading all these posts...its got me goin' !
  6. #175
    Join Date
    Feb 2013
    Posts
    6,573
    Thanks
    31
    Default
    All the ones I have bought had the ac and dc power cable. The dc cable is just a long pigtail. If you look at the listing pics and see the two cables then you should be good. Slave connectors are a common item easy to get.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
