Page 6 of 7 FirstFirst ... 2 3 4 5 6 7 LastLast
Results 51 to 60 of 67
Thread: Working on the FV1801A or Truck, 1/4 Ton, 4×4, CT, Austin Mk.1 AKA Austin Champ
  1. #51
    4 Star General Keith_J's Avatar
    Join Date
    Aug 2009
    Universal City TX
    Posts
    2,787
    Thanks
    17
    Default
    Its ALIVE!! After two days of carb fiddling, I can say I know how this Solex carb works. All circuits clean and passed vacuum tests but it was still running rich and improper so I hooked a vacuum gauge to the manifold, 14.5 inches of mercury is sick. I bumped timing to max with only a minor improvement so I tried to jump a tooth on the distributor thinking it was incorrect from acquisition, no luck as the gear is buried.
    In doing so, #1 plug was loose so I pulled it, normal gray color?? So I pulled #2 and it was black and wet. It wouldn't throw a spark with all that carbon so it and the rest got a torch cleaning plus carb cleaner..and that was the secret sauce! The engine runs smooth, strong and clean. Just needed an Italian tune up to burn the rest of the carbon out as it intake backfired on me once.
    Now we need to get the brakes running. And fix the M37 as its ignition decided to go on strike today.
    Please keep ethanol at the bar in bottles and not in your fuel tank. Alcohol and vehicles do not mix. And it kills fuel systems.
    1986 M1031 SECM.
    1985 MEP 002A
    1974 MEP 026C, eventually converting to electric start.
  2. The Following 2 Users Say Thank You to Keith_J For This Useful Post:
    M813rc (10-18-2018), tennmogger (10-18-2018)
  3. #52
    4 Star General mkcoen's Avatar
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,452
    Thanks
    935
    Default
    Getting a little frustrated with these brakes. We rebuilt the master cylinder, all the wheel cylinders, bled the lines and it still won't stop unless you're standing on top of the pedal and already just rolling. We did discover one set of wc cups that were not the listed 1 1/8". They were at least about 1/32" smaller so were allowing the left front wc to leak. Luckily I had a couple of spares that were the correct size.
    Did fix the M37 issue with new points, condenser, and plugs. I can certainly see why it's easier to set the points with the distributor out.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
    US ARMY - Overlanding since 1775
  4. #53
    Join Date
    Aug 2009
    Universal City TX
    Posts
    2,787
    Thanks
    17
    Default
    I think the leaking left front wheel cylinders caused air to get into the right rear wheel cylinder. I need to look at an RV in your neighborhood so noon tomorrow?
    1986 M1031 SECM.
    1985 MEP 002A
  5. The Following User Says Thank You to Keith_J For This Useful Post:
    mkcoen (10-24-2018)
  6. #54
    Join Date
    Aug 2009
    Universal City TX
    Posts
    2,787
    Thanks
    17
    Default
    Got good brake pedal now. The front adjusters are like a M35 but coarser. The rears are very fine. All 4 needed adjusting.
    Now the only issue is glycol soaked linings. A trip through a toaster oven at 300 °F overnight will fix that.
    1986 M1031 SECM.
    1985 MEP 002A
  7. The Following User Says Thank You to Keith_J For This Useful Post:
    M813rc (10-26-2018)
  8. #55
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,452
    Thanks
    935
    Default
    Brakes "kinda" work. You pretty much have to stand up on the pedal and be going slow to start with but it will stop.
    Now the major issue is charging. Only getting 23.9v at both the alternator and the batteries so it doesn't take much running to run down the batts. A couple of thoughts I had was either loose belt or bad ground. Unfortunately this is not "factory" and there is little to no adjustment on the belt. I have it as tight as it will go and that didn't change anything. Next I pulled the unit and cleaned every connection point and added star washers to every bolt. Whoever painted the engine left the alt in when they did it so everything was pretty much painted over. Again, no joy. Still holding steady at 23.9v.
    Keith is going to be out tomorrow to work on his RV Tug so maybe he can suggest something else. If there's no other option I can get a new 24v alt for $76 with free 3 day shipping.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
  9. #56
    Join Date
    Aug 2009
    Universal City TX
    Posts
    2,787
    Thanks
    17
    Default
    I can wrangle something with the alternator. There are about a Brazilian parts from that company named after a South American river
    1986 M1031 SECM.
    1985 MEP 002A
  10. #57
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,452
    Thanks
    935
    Default
    In order to make sure the Champ was ready for the Austin Veteran's Day Parade I went ahead and ordered a replacement 24v alternator. If Keith wants to monkey around with the old one then I can just have a spare for backup. The new alt showed up this morning and I got to work making it usable. First thing to do was swap out the pulleys. The old pulley had a 1" nut while the new one was 15/16th. Unfortunately I didn't have either of those sizes in an impact socket so had to go buy some new tools (darn). Once back from Home Depot both nuts zipped off without any issues. Luckily the shaft on both were the same size and the threads matched as the nut on the old pulley had a threaded shoulder that fit down into the pulley. The new alt nut wouldn't have had enough threads to grip it well enough (well maybe it would but why risk it?). Everything went back together as easily as it came apart and now we have 28.8v at both the alt and at the batteries. To celebrate I took it for a spin down to the gas station to get a little Super Unleaded. I have to admit it's a bit scary to drive with all the rattling and thumping coming from underneath. Having never had one of these before I don't know how much of that is normal and how much is something about to explode.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
  11. The Following 2 Users Say Thank You to mkcoen For This Useful Post:
    m38inmaine (11-01-2018), M813rc (11-13-2018)
  12. #58
    4 Star General m38inmaine's Avatar
    Join Date
    Nov 2006
    Maine USA
    Posts
    2,032
    Thanks
    639
    Default
    Good job Mark, glad to see it out and about.
    SSG USA(RET)
    85-05
    12B Combat Engineer
  13. The Following User Says Thank You to m38inmaine For This Useful Post:
    mkcoen (11-01-2018)
  14. #59
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,452
    Thanks
    935
    Default
    Starting to “think” about the body repairs on the Champ. It’s a little difficult not having a “correct” example to compare things to so hopefully some of the limited number of owners can chime in here.
    The front end end has some obvious damage but not really obvious as to how things should line up once repaired. The grille, hood, fender areas don’t match up but the grille doesn’t look so damaged as to be off by that much. The first question is does the top of the grille line up with the outside edge of the hood or does it sit back any?
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
  15. The Following User Says Thank You to mkcoen For This Useful Post:
    M813rc (11-13-2018)
  16. #60
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,452
    Thanks
    935
    Default
    Think this pic answers the question.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
