Service Your Air Dryer
allie
11
equinunk pa
Gonna do it! Have one more issue I wish I could fix. Engine doesn’t shut Down with switches I have to pull the emergency shutoff then open hood and reset it so I can start it
Thank you.
1,166
See if the thumbwheel on the shut off solenoid has been screwed, to manually override the solenoid.
allie
11
equinunk pa
Ok thumb screw was all the way In. I backed it off all the way and truck wouldn’t start , wasn’t getting fuel. I then screwed it back in just not all the way and it now runs , shuts off and starts with the switches. Hope that screw doesn’t back out on its own from vibration.
The canister wasn’t leaking it’s leaking from above that and in an area I can’t figure out how to get to. I took a video and some pictures of it leaking. Gonna try to post them.
porkysplace
1,484
mid- michigan
If it doesn't run with it all the way out you still have a issue that needs to be addressed . it sounds like the fuel solenoid is going bad .
https://www.eriksmilitarysurplus.com/fucova24vofo.html
