Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: save M715 original or making it practical ?
  1. #21
    General
    Join Date
    Jul 2005
    KINGSPORT, TN.
    Posts
    489
    Thanks
    Default
    45 MPH is wide open............ forget diesels cost is very prohibitive and the noise is horrible plus it stinks . I have 4bt,s and 6bt,s and I would not install one for myself under NO circumstances. sbc is the way to go imo. 1 day out, 1 day in and your done. I,ve done a bunch both ways..................
    I BELIEVE IN JOHN 3:16
  2. #22
    4 Star General snowtrac nome's Avatar
    Join Date
    Nov 2016
    western alaska
    Posts
    1,552
    Thanks
    Default
    a little 4bd Isuzu diesel would be a nice fit from an Isuzu npr they rev higher than a 4 b, are quiet and last for ever.
  3. #23
    Corporal
    Join Date
    May 2010
    ST. LOUIS, MO
    Posts
    35
    Thanks
    Default
    I have a 6bt , 5 speed and 410 gears and get 16 mpg on the highway.
  4. #24
    Sergeant
    Join Date
    Mar 2019
    Albany NY
    Posts
    87
    Thanks
    Default
    It's YOUR vehicle so do what you want with it......BUT since you asked:
    These vehicles are all part of history and one day will be extinct ( look at all the surplus aircraft after WW 2, where are they?). Most younger folks today have no interest in history so it's only getting worse. IF your Jeep is average shape then why not,
    have at a custom project. But if it's unusually clean I'd say don't make any mods that can't be easily undone.
    Again, only my opinion and I respect your right to do as you wish.
    1971 M35A2 WO/W
    1953 M38A1
    2000 Jeep Wrangler wheeled and lifted
    2013 F 150 wheeled and lifted
    Few other toys
  5. #25
    4 Star General saddamsnightmare's Avatar
    Join Date
    Nov 2007
    Abilene, Texas
    Posts
    3,541
    Thanks
    1,128
    Default
    June 8th, 2019
    We had a stock M715 that took considerable abuse by then then owner, who could mess up an iron ball with a rubber mallet. Beyond the water pump failing due to the four belt pulley load on the front bearing, and minor carb issues, the only other thing of note was the owner blew a hole in the floorboards when the starter switch shorted. That was an exciting day to be sure, electrying, you might say. But the truck could pull 4 pallets of brick at 50 on the level, and I feel the design was much abused, wrongly, by people who haven't learned to work on the truck as a stock unit. IF you must mess, I challenge you to get a KIA M450 and mess that one up.....!
    Cheers,
    Kyle F. McGrogan
    1963 Swiss Cargo Unimog S404.114 "Helga" (after Haagar's wife!). Found a new home in Michigan 5-5-2019
    1971 Kaiser Jeep M35A2 WoW "Saddam's Nightmare" Desert Storm and Vietnam Veteran Deuce and a Half.
    (Sold in Texas 4-3-2012)
    1968 Johnson Corp M105A2 Cargo Trailer.
    1967 Hercules MEP023A gas Gen Set "Rev up your C130 Here!".(It went to Perrin Field AFB Historical Society Museum at Dennison,TX.)
    Looking for a USAF Step Van in Abilene, TX area!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
