Saving a couple OH-58's
Tinstar
1,708
Edmond, Oklahoma
Hopefully you mean “flyable” condition.
Flying means airborne.
Get caught flying it, even a low hover, without the required paperwork, etc and you’ll wish you never saw it.
Saw a guy do that with a Huey.
Restored to flyable condition and had almost zero paperwork for work done as it was for “ground only display”.
No AWC, etc.
Idiot hovered it within sight of a US Customs Hanger and the airport control tower.
Aviation is a small community and the whole airport knew what the Huey was intended for.
FAA was there bright and early next morning.
It did not end well for the guy.
Buying a surplus aircraft is cheap.
Getting it flying is very expensive.
Both Flying condition and FAA Airworthiness Certificate is extremely expensive.
You can get a decent BlackHawk Helicopter for under $500K, but you’ll spend millions getting all the inspections and overhauls and replacing timed out components.
Just one main rotor blade is $75,000.
Not one set......1 blade.
Price adds up fast.
Switchessafe
Calhoun Georgia
Nice. I am up near Calhoun Georgia and I am building a oh-58 for static as well. How’s your project going? I would be interested in trading around parts if we can help each other.
poof
Dirty Hippie
568
19
Wisconsin, Watertown
No AWC, etc.
Price adds up fast.
If he would have just attached a rubber skirt on it and called it a "Hovercraft " ..that's my story and I'm sticking to it..��
Ras1
39
Rockford, illinois
Just a thought, these things are hard to move around in the shop as they don't have wheels. I have spent lots of time chasing down parts, and found the original ground handling wheels.
They are different than Bell 206, or any other helicopter for that matter, they fit specifically the OH-58, and clip to the skids in seconds. It allows you to move the helicopter around.
I have an extra set if needed.
USAFSS-ColdWarrior
Chaplain
5,507
DaveView attachment 764268
Cool.
Seems to be a rare find - and very handy, too.
Tinstar
1,708
Edmond, Oklahoma
Dave
Recommend Replacing the tires and tubes with new ones.
Ground Handling Wheels are often abused and maintenance deprived.
Dry rot tires, no grease and usually low on air.
If one pops, the one right beside usually goes shortly after.
I’ve seen one side blow the tires and cause the Helo to do an almost 90 degree turn, putting the tail boom right into the hanger door.
Threw the guy holding the vertical fin, down like a rag doll.
$80k damage due to old tires that cost less than $100 to replace.
Probably wouldn’t do that to a stripped Hull since it’s so light, but you get
the idea.
Ground Handling Wheels are almost always Helicopter model specific.
Bell 206, 206-L4, 407, etc are all different.
Cannot use one on the other.
That’s why we land on trailers at work.
Then simply jump on tractor and push it inside.
When maintenance is required, the maintenance facility has the correct wheels for each model to get it inside the maintenance hanger.
