Results 1 to 6 of 6
Thread: FLU419 mystery rubber hose
  1. #1
    Corporal joeblack5's Avatar
    Join Date
    Feb 2015
    State College PA
    Posts
    42
    Thanks
    14
    Default FLU419 mystery rubber hose
    When I worked on the alternator I wound a rubber hose that goes from the top of the power steering reservoir and converts in a plastic ( nylon) line that goes to the housing of the engine hour counter.
    The rubber ends were in a bad shape so it did not fit together and I will replace it but what is the function?
    Thank you J
  2. #2
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    Quote Originally Posted by joeblack5 View Post
    Thank you J
    It is a vacuum hose for the power steering pump reservoir. I think anyway. I think the idea is to get bubbles / froth from circulating. At least that's my story and I'm sticking to it.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  3. #3
    Join Date
    Feb 2015
    State College PA
    Posts
    42
    Thanks
    14
    Default
    Thank you Rtr. I did not realize that the housing that holds the engine hour meter is also a vacuum pump.
    later J
  4. #4
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    144
    Thanks
    96
    Default
    later J
    To be honest it is a bit of a guess. My mog had the same hose connection issue, and I scratched my head about it. It can't be for fluid because there is just one line. Vacuum was all I could come up with.
  5. #5
    4 Star General
    Join Date
    Dec 2006
    Greenback, TN
    Posts
    1,239
    Thanks
    1,412
    Default
    It's just a vent.
    1952 M-38
    LST-178 Lube and Service Trailer
    M-1082 LMTV Trailer
    2 x M-105 trailer, bare
    M-105A2 with sides, bows
    'old' Onan 115 v radar power generator, 4 cyl boxer engine
    2 x S-250 Shelter, 318 shelter
    1957 Unimog 404 flatbed, French NATO (Germany)
    1965 Unimog 404 radio truck (German Army)
    1967 Unimog 404 flatbed project truck
    3 x Unimog 406's
    1988 Unimog U-1300L with 10' NCO Alaskan Camper
    1968 Haflinger bug-eye US version but pre-Pathfinder.
    1994 M-1078 LMTV with 10' NCO Alaskan Camper
    1995 M-1078 LMTV
  6. The Following User Says Thank You to tennmogger For This Useful Post:
    joeblack5 (06-01-2018)
  7. #6
    Join Date
    Feb 2015
    State College PA
    Posts
    42
    Thanks
    14
    Default
    Thank you Tennmogger, i will treat as such.
    later J
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
