cucvrus
- 9,603
- 113
- Jonestown Pennsylvania
Fix the problem first before you go do a lot of changing. IMHO you are just adding more equations to the problem by changing everything when you do NOT even know what is wrong and causing the issue. Save a lot a time and money. The fuel filter base may be the issue. But it may NOT be the issue. But do as you wish. I have never had issues with the fuel filter base that a self tapping screw and sealer couldn't fix or a $40. pressure switch. But again do as you wish. Some advise is don't dance around the issue. I say the injection pump is leaking and that will make air bubbles in the fuel also. Have a Great Day. And like Burger King. All I ask is to have it your way. Good Luck.
