moehos
- 2
- 3
- Fairbanks Alaska
Hi all,
new to the forum, though ive been haunting the threads for a long time.
The other day when I started my CUCV, the Gen 2 light came on and stayed on for the long drive home.
Upon getting home, I tested the current at the back of gen 1(drivers side) and found 12-13volts and tested the current at the back of gen 2 (passenger side), 11 volts. Bad alternator, easy peasy. Ordered a new one from Romaine Electric, installed it and whoops, no generator light...
No gen 2 light when ignition in the on position, no light when running.
So, swapped old alternator back on, gen 2 light on all the time, running or not.
So the light works. Checked and cleaned the socket. Checked and cleaned the leads for the top plug terminal, checked fuses; No luck.
My preferred electrical shop is closed for the 4th of July weekend so I took both the new and the old alternator to Oreilly's and they very kindly tested both units. Results; old alternator is dead as a doornail, new alternator passed with flying colors. Not sure what all their whiz bang machine tests for, but the young man operating it certainly didnt have any insight.
Now, I am no electrical genius, but it seems to me that something must be wrong with the new alternator. Perhaps it is generating power but the function that sends power to the gen 2 light isnt working. I understand that there is a relay and diode under the dash for GEN 2, but it seems to me they must be working if the Gen 2 light comes on with the old alternator.
Thoughts?
Thanks in advance!
Thoughts?
Thanks in advance!
