Results 1 to 4 of 4
Thread: Mystery Vision block /door stop😧
  1. #1
    Private
    Join Date
    Aug 2018
    Sacramento
    Posts
    Default Mystery Vision block /door stop😧
    Found a vision block at a yard sale. The owner was using it as a door stop but the glass is in amazing shape with no chips or scratches. Trying to find out exactly what type vehicle it was used in. Itís a trapezoid shaped unit with multi layer glass about 4 1/4 in thick. Itís about 9 inches wide on the front and 6 1/2 wise on the rear and about 3/1/2 to 4 inches tall (tapered) and has a part number on one side that is stamped in.
    11602005 and also says L.O.F which I think stands for Libby Owens Ford ? If anyone has any info I would love to hear it. I have googled these numbers till Iím blue in the face and can find nothing. 😕
  2. #2
    4 Star General mkcoen's Avatar
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,533
    963
    Default
    How about posting a pic?
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
    US ARMY - Overlanding since 1775
  3. The Following 5 Users Say Thank You to mkcoen For This Useful Post:
    98G (08-17-2018), firefox (08-08-2018), Guyfang (08-07-2018), porkysplace (08-07-2018), USAFSS-ColdWarrior (08-08-2018)
  4. #3
    Private
    Join Date
    Aug 2018
    Sacramento
    Posts
    Default
    Would love to post a pic but I see no way to do so
  5. #4
    Chaplain USAFSS-ColdWarrior's Avatar
    Join Date
    Jun 2009
    Posts
    16,658
    57,234
    Default
    Quote Originally Posted by Supersonic View Post
    In the QUICK REPLY box you will see a tool bar at the top. One of the icons available looks like a picture frame with a black dot at each corner. Hover your cursor over it and you will see its function is INSERT IMAGE. Click on it. The dialog box that pops up is fairly simply to navigate.
    We look forward to your pictures to better help you identify this gem.
    And by the way.....
    Welcome aboard Find a bunk, stow your gear, and prepare to get underway
  6. The Following 4 Users Say Thank You to USAFSS-ColdWarrior For This Useful Post:
    firefox (08-08-2018), Guyfang (08-08-2018), marchplumber (08-08-2018), Migginsbros (08-08-2018)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
