peakbagger
- 344
- 63
- northern nh
You may want to PM Speedwoble. I think he had a SEE with bad transmission and seems to know his stuff. He also fabricates cab lifting brackets that you will need at some point. He makes them up and Expedition Imports sells them. I hope the transmission issue is external to the transmission. You got your SEE for a good price, even if you have to lay out bucks for new transmission it may be worth it. I would Check C&C Equipment and EI as possible sources.
It sounds like you have the right attitude for owning a SEE. Some folks are in way over their heads but it looks like you know what you have. Out of curiosity was the rock drill you used a Stanley rock drill that SEEs came with or did you use something different? Given my soil conditions I expect I will be splitting more than a few boulders and was curious how the stock SEE rock drill works on real rock? I have considered setting up fixture to mount the drill on the bucket and use the bucket to grunt the thing in place and hold it while drilling.
To date I haven't seen many females who appreciate the charms of a SEE
