Prepping Deuce for paint
russojap
Knoxville TN
This is a dumb question I guess, but do you guys think I should dress up the terrible looking welds on the bed sides and the cab under the doors? They didn't even scrape the weld spatter off... terrible workmanship.
It's also too late now but I am concerned about the paint dust getting all in the yard. I assume it will just filter down into the ground after a rain or two. Thanks.
RickWG
LA Ca
Ok so here is a quick update. The coal slag does seem to work removing rust but isn't very good at removing paint. But my compressor is also only a 25gal. one with a regulator or whatever the part that kicks it on not working correctly. Also I can only operate the gun a few seconds before water starts spraying out ,so will have to add an inline filter I guess.
The air coming from the comp needs to cool down before it gets to the water separator. 50ft of hose will help with that (50ft of copper pipe is perfect, but spendy). Also need to drain the comp water doodad on the bottom of the tank quite often. So Compressor > 50ft hose > water separator > hose to blaster. & get a proper water separator like a Sharpe 606 etc.
