maniatopoulosg
- 7
- 18
- Miami
So I went ahead and did the well nut replacement are used the metal replacement not plastic thank you callmecolt from YouTube this one was not easy I actually had to go in on the motor side remove the primary fuel pump fan shroud and unbolt the gusset that is holding the gas tank down just so I could swing it out-of-the-way for the fuel tee to swing tight took me an extra few minutes I don’t want to take the tank outThanks for coming back to post your finding the problem! It really helps others in the future when people come back and post what the solution was to their problem (it can help show a trend, which in this case the well nut is already known to be). Often times OP's seem to spend a lot of time in a thread picking brains on what the problem might be and never come back to close the loop and the thread is left dangling with no solution.
I also had a problem landing the Bulkhead fitting through the tank I had to use the angled side of the amp probe wire
Chainbreaker
Guy
Light
Thank you for your help
