Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Red Dot A/C install help
  1. #1
    2 Star General LiveFreeOrDieTryn2B's Avatar
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default Red Dot A/C install help
    Ok gous I just got a nos A/C unit and the evaporator and some A/C lines. I did some reading on here to try to find some help with the install. I will need to source a compressor and make or find brackets for it. Here a video.
  2. #2
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    Ok guys Ive been researching here and online about this A/C. I am wonderimg if the Red Dot Humvee compressor will work can I get it in a double groove pulley configuration, or swap to the correct pulley? I am going to mount the the 3 fan evaporator in the video on the roof of my shelter box or the front wall of it. Any and all advice on the compressor and or other parts is greatly appreciated.
  3. #3
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    Ok guys Im looking at a Denso style compressor for a Cat. I can buy the adapter for the AC lines. Not sure of the rotation yet but will find out for sure today. It looks like a I can only use one pulley groove on the inside because the outer is smaller. I can fit it on either side of the engine either on air compressor belt or alternator belt only can use one if I mount it to that side depending on rotation. On a side note the Denso does nt require as much engine power to run as the Sandon style from what I read while researching.
  4. #4
    4 Star General cattlerepairman's Avatar
    Join Date
    Jul 2007
    NORTH (Canada)
    Posts
    1,723
    Thanks
    759
    Default
    Waterloo specialties makes a basic kit that could come in handy.
    Sent from my SM-T560NU using Tapatalk
    MVPA member. 1974 M35A2C w/w "Queen Lola", rebuilt LDS-465-1A, "D" turbo, Waterloo Overdrive upgrade. Med towbar, 11.00R20 Goodyear G286, flipped hubs, remote brake fluid reservoir, bypassed FDC, LED taillights, LED headlights, LED turn signals, WESTACH EGT/boost gauge, AVM lockout hubs, LED convoy light, LED lollipop lights, HMMWV seat on air ride base, M211 dash passenger grab handle, hood lift kit, 24V solargizer/battery minder, ether start kit, flasher module mod, heavy duty dog bone ends, M35A3 aluminium fuel tank.
  5. The Following User Says Thank You to cattlerepairman For This Useful Post:
    LiveFreeOrDieTryn2B (11-05-2018)
  6. #5
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,061
    Thanks
    101
    Default
    or a sanden 4311 is a 24v double groove pulley compressor that works on various brackets. Mount the condensor behind the cab.
    2008 F-250 6.4L Powerstroke
    1984 AM General M923A1 ( Big Cam III NTC-400, HT3B turbo, Intercooled, #15 button, Dual fuel Line setup - MRAP Aluminum Radiator - 8" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    83' M923A1
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  7. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    LiveFreeOrDieTryn2B (11-05-2018), silverstate55 (11-05-2018)
  8. #6
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    That is an awesome video here's some pics of of my truck and some mounting ideas. I'm going with the double v groove Sanden style compressor.
    Attached Images Attached Images
  9. #7
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    Here's more pics. I will be picking up Toms AC kit as well I'll have to give him a call.
  10. #8
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    Well I ordered the compressor Simp suggested still have to order Toms bracket kit. It's coming together.
  11. #9
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    Ok I ordered Toms AC kit today I hope that I wont have any issues with mounting the 4311 vs the 508.
  12. #10
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    671
    Thanks
    276
    Default
    Ok guys I have access to as many soft lines as I'll need. I need an idea of any other lines or fittings I'll need or other parts thanks.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
