Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: 6.2/6.5l Turbo kits
  1. #21
    Colonel JoeJrTheBarber's Avatar
    Join Date
    Jan 2018
    Chicago, IL
    Posts
    249
    Thanks
    Default
    Quote Originally Posted by Lazboytt View Post
    I would like to see pictures of that
    Random pictures I found online:
    148_0502_turbo_12_z.jpg973081b4c8575a8e34be9b4e6b4ae107.jpghrdp_1008_16_o-low_mounted-turbo_systems.jpg
    Obviously each setup is different in size of turbo, number of turbos, size of inlet/discharge tubing, turbo placement, etc.
    With the amount of room with the stock muffler gives up once removed I cant see this being a issue on a Humvee. We will find out come this spring/summer when
    I do it to my truck..
    Think outside the box people !
    JoeJrTheBarber
    Chicago, IL
  2. #22
    Administrator patracy's Avatar
    Join Date
    Jul 2006
    MVPA
    37424E
    Posts
    13,217
    Thanks
    1,218
    Default
    Might want to research the remote turbo more. Lag is an issue for all of them in some manner. Also there is the oil supply and return line issues. Most use electric oil pumps to scavenge and return the oil. Also you're giving up a lot of thermal energy in a remote setup.
    I'm not saying it can't work. Just that it's not a simple work around, just brings new issues.
    Sent from my SM-G965U using Tapatalk
    M114
    1992 M1038
    1969 M35A2 wo/w, hoist in bed, heater, Ooga horn, Recentered HEMTTs and 395's, "Candy Smasher"
    1968 M543A2 Wrecker - You know, for heavy lifting...
    1984 M931 - SEMTT project
    198? M270 trailer TBD...
    1985 M1008 - SMOKEY 8" lift, 37" humvee 24 bolt wheels/tires, turbocharged.
    And a few M105 and M101 and other trailers
  3. #23
    Join Date
    Jan 2018
    Chicago, IL
    Posts
    249
    Thanks
    Default
    If your worried about "turbo lag" in a humvee you have the wrong vehcile my friend.
    JoeJrTheBarber
    Chicago, IL
  4. #24
    Join Date
    Jul 2006
    MVPA
    37424E
    Posts
    13,217
    Thanks
    1,218
    Default
    Turbo lag doesn't also harm performance, having excess fueling and not enough air causes egt to soar. Which can harm the engine.
    M114
    1992 M1038
  5. #25
    Join Date
    Jan 2018
    Chicago, IL
    Posts
    249
    Thanks
    Default
    A turbocharger doesn't know or care where it is placed In the system (so to speak) as long as everything is running as it should.
    if anything a rear mounted setup would keep the turbo itself (and EGT's) lower / cooler then being stuffed ontop of a hot motor in a cramped engine bay.
    JoeJrTheBarber
    Chicago, IL
  6. #26
    Join Date
    Jul 2006
    MVPA
    37424E
    Posts
    13,217
    Thanks
    1,218
    Default
    The further away from the engine the longer it takes for the exhaust gasses to travel. Also the surface area of the exhaust will certainly lower the inlet temps into the turbo. A Turbo uses the thermal energy of the exhaust to spin, not just the velocity of the exhaust itself. Now to clarify another statement. Having the turbo not in the engine bay could possibly decrease inlet air temps, that could result in lower EGTs and better operation. But the same can be done by simply ducting the turbo inlet to just fresh air.
    Now consider mounting the turbo under the tub where the muffler is. There's probably 15ft of exhaust for it to pass through, then another 15ft of duct to return to the intake. The biggest issue with remote mounted turbos like this is the delay this naturally causes. Another thing to consider is inlet air. Most cars that hide the turbo under the cars also have the air filter down there on the turbo as well. For a street car or something not driven in the rain, no biggie. But not at all what a HMMWV is for. You'd need to then duct inlet air down there for another 15ft of piping. Or pull it up into the tub. (I can't recommend that though, a screeching turbo right there in the cabin with you along with intake noise is going to get old)
    Understand also how a diesel works. The injection pump simply dumps in fuel as requested. There's no throttle valve on a diesel to control RPM. The engine simply increases RPM based on the fueling presented. So when you mash on the pedal, the pump just meters out more fuel per injection, then the engine spins up (or maintains speed if load has increased). When you add in a turbo to the mix, the turbo's response is based solely on it's characteristics to the exhaust and it's compressor flow. You can have a greatly oversized turbo that could flow all sorts of air, but if the engine can't spool the turbo, you'll never see the boost increase and cleaning up of the exhaust. The black soot you see is unburnt fuel that goes hand in hand with EGT. The way to clear that up is to decrease fueling, the turbo "spools" and air flow is improved, or the engine RPM needs to be increased to flow more air. The engine RPM can be increased by downshifting, but if you're locked into top gear, the turbo isn't going to spool and EGTs soar way out of control.
    I'm dealing with the later in a way on my CRD. It has a VGT (variable vane) turbo. These turbos have a tendency to stick the vanes. Mine sometimes sticks at the higher position where more drive pressure is bypassed. This causes low boost at low RPMs and excessive EGTs. I really need to pull the turbo and try cleaning the vanes.
    M114
    1992 M1038
  7. The Following User Says Thank You to patracy For This Useful Post:
    TOBASH (12-17-2018)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
