Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Some Rapco spray paint pointers
  1. #11
    General SturmTyger380's Avatar
    Join Date
    Nov 2006
    Easley SC
    Posts
    456
    Thanks
    Default
    Yep, gunsgreg has it, in the winter if I want to paint I take the cans to the house and set them on a heat register for a few days. Another thing I do is when I am done I clean the spray nozzle with acetone and blow compressed air through it. I also put a little acetone down the hole where the nozzle goes and blow it out with air. Not sure if that helps or not but makes me feel better.
  2. The Following User Says Thank You to SturmTyger380 For This Useful Post:
    jeffhuey1n (08-07-2019)
  3. #12
    Private
    Join Date
    Oct 2018
    Eastern NC
    Posts
    Thanks
    Default
    Thanks for all the suggestions guys!
    Jealous of those who have had good luck with it. It has been a bit of a nightmare for me. And it seems these cans have had the same issues for a long time.
    I will try these suggestions.
    I've heard good things about the Ron Fitzpatrick paint, so that's an option I might try too.
    Thanks again
  4. #13
    Private
    Join Date
    May 2017
    Richmond, Va
    Posts
    10
    Thanks
    Default
    I have had good luck with Rapco paint also. I typically turn the can upside down for about 2 hours before I start to shake it. Seems to help.
  5. #14
    Sergeant Major Brutacus's Avatar
    Join Date
    Jul 2016
    Marion, AR.
    Posts
    120
    Thanks
    26
    Default
    One issue you might be having with the spray can is over shaking. Sounds strange, but it's true. Some of the cheaper made rattle cans use a GLASS marble instead of metal ball bearing. Over shaking can cause the glass marble to chip and cause glass flakes to clog the nozzle. I found this out from a bargain bin special camo paint spray cans (one busted open, and made a HUGE mess). I never opened a Rapco can, so I can't say this is the case for the Rapco cans. Now I too prefer the Rapco paint, but I also agree the nozzle can be improved. I never shake my for more than two minutes. And after countless cans that have clogged up on me, I've ditched their nozzle and just reuse older rustoleum ones until they clog up.
  6. The Following 2 Users Say Thank You to Brutacus For This Useful Post:
    BKubu (05-26-2019), frank8003 (05-26-2019)
  7. #15
    Private
    Join Date
    Feb 2017
    Montague, Texas
    Posts
    Thanks
    Default
    I have found that if a can starts to have issues, I will take the second spray tip that comes with each can and remove the small nozzle in the center. I then place this altered
    spray tip in the can and holding the can upside down, spray until the sound changes or it stops spraying color and is just spraying the propellant. I then take a new spray tip
    and go back to painting. I have learned that the Rapco paint is very dense compared to other brands like krylon or Rustoleum, which seems to be the root cause of the tips
    getting clogged up. I save the clogged tips and place them into a prescription bottle filled with acetone and blow them out with air from the compressor....tips are like new.
  8. The Following User Says Thank You to texwelder For This Useful Post:
    silverstate55 (08-08-2019)
  9. #16
    4 Star General Tinwoodsman's Avatar
    Join Date
    Aug 2010
    Comfort, Texas
    Posts
    3,881
    Thanks
    1,848
    Default
    Brent Mullins Jeep parts sells a great spray paint.
    "If wishes were horses, beggars would ride"
    1942 GPW
    1942 Ben Hur Trailer
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
