Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Locking hubs
  1. #1
    Corporal
    Join Date
    Oct 2018
    Maryville MO
    Posts
    26
    Thanks
    Default Locking hubs
    I m sure this has been posted before but I did a search and did not find anything. I have a 53 REO M35 that I was curious about putting manual locking hubs on. Does anybody have a link or part number and where to price or even start to where to look for them? I am not dead set on getting them and am weighing the pros and cons.
  2. #2
    4 Star General rustystud's Avatar
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    7,742
    Thanks
    2,217
    Default
    Quote Originally Posted by CHM View Post
    "Ouverson" sells them. Pricy though. Here, http://www.ouversonusa.com/
  3. #3
    Sergeant mcv1964's Avatar
    Join Date
    Apr 2018
    Martin City, MT
    Posts
    58
    Thanks
    33
    Default
    I'm curious of the pros and cons as well.
    Never thought of it or would understand why to or not to do it.
    Hmmmm
    Blessings to you and yours!
    Monte
  4. #4
    LLM/Member 785 Recovry4x4's Avatar
    Join Date
    Jun 2004
    Posts
    33,313
    Thanks
    747
    Default
    Your 53 likely has a spray transfer case. If it does, lockouts are of very little value.
    1986 M1008
    1984 M1031
    1984 M1010
  5. #5
    Corporal
    Join Date
    Oct 2018
    Maryville MO
    Posts
    26
    Thanks
    Default
    I do not know a whole lot about these as this is my first one. Why would they be of little use on the spray transfer case? Not arguing or anything just curious how the spray operate and why they would be of little use.
  6. #6
    4 Star General porkysplace's Avatar
    Join Date
    Apr 2009
    mid- michigan
    Posts
    8,341
    Thanks
    5,651
    Default
    Because the sprag unit sends power to what ever axle spins , with louts the front drive line would be under power all the time , just not giving the wheels power because of the lockouts.
  7. #7
    Join Date
    Sep 2011
    Posts
    7,742
    Thanks
    2,217
    Default
    Quote Originally Posted by Recovry4x4 View Post
    Actually "lockout" hubs will prevent wear on the front differential as the wheels are constantly turning the axle shafts thus the differential gears. Also it would help with steering as the axles turning creates a "drag" or "shimmy" on the steering at high speeds. Just ask anyone who has a 4X4 who left his hubs locked.
  8. #8
    General fsearls92's Avatar
    Join Date
    Jul 2011
    Jacksonville, FL
    Posts
    596
    Thanks
    144
    Default
    I personally would stay away from them. I have them on my truck and do not like the fact that they allow moisture into the hub and have caused rust multiple times. I have replaced the gaskets multiple times with the same turn out every time. Last issue I had was they would not lock because of the moisture and rust. Had to disassemble the locking mechanism and clean it all out in the sand. I personally wish I had the factory flanges still (but I sold them).
    1965 Kaiser M35a2C w/w whistler on 395's
    1954 REO M35a2 (sold)
    1971 AMG M35a2 (sold)
    1972 AMG M35a2C w/whistler on 395's- (sold)
    1972 AMG M35a2C (sold)
    1972 AMG M35a2 (sold)
    19?? AMG M109a3 (parts truck/ all gone)
    1985 AMG M923A1 (sold)
    1990 BMY M923a2 (sold)
    19?? M105A2 (sold)
    19?? M105a2 (sold)
    7-M101A2 (all sold)
  9. #9
    Corporal
    Join Date
    Oct 2018
    Maryville MO
    Posts
    26
    Thanks
    Default
    Thanks to all for the advice and information. After reading the forums and giving it some thought I believe that I will not get them and put the money into the truck somewhere else.
  10. #10
    Moderator m16ty's Avatar
    Join Date
    Mar 2007
    Dickson,TN
    Posts
    9,535
    Thanks
    965
    Default
    The pros are, it will save on frontend wear, tire wear and fuel mileage (providing you have a air-shift t-case).
    The cons are mainly price, and if you have a sprag case it will cause your t-case to be engaged all the time.
    In my opinion, unless you are driving a bunch of miles and have a air t-case, save your money.
    The only member that ever gave himself a infraction point.
    www.americanmachinerymoversinc.com
    1972 M35A2C dump w/w (nothing more than a hunk of scrap iron between two winches)
    1985 Mack RD822SX (Operation Desert Storm veteran)
    M1000 transporter
    1967 M715
    M101A2
    4- M105s
    M149A2 tanker trailer
    M49 parts truck
    M35A2 parts truck
    M936 (converted to lime spreader truck)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
