Results 1 to 2 of 2
Thread: HEI Distributor conversion
  1. #1
    Corporal
    Join Date
    Feb 2008
    Vermont
    Posts
    34
    Thanks
    Default HEI Distributor conversion
    There are several HEI (GM) distributor conversions for the Dodge 318 engine for sale from various places.
    Has anyone used one in an M880? That is a huge distributor cap, compared to the stock one, and I am wondering whether it would fit without modifying the firewall.
    I am sick of fighting with the stock ignition, and the associated rotting wiring. The conversions require just a hot wire from the switch and done. This is a working truck, and it should be working, not getting worked on.
  2. #2
    3 Star General N1265's Avatar
    Join Date
    Jun 2005
    Fremont, Ohio
    Posts
    995
    Thanks
    Default
    The bigger distribuitor cap units will not fit without modifying the firewall. I did however do the HEI conversion with a smaller unit from Skip White with good results. ( have since had to replace the ignition modual x2 ) and went a step further the last time by locating the modual by the brake booster and using a standard GM one to make it easier to replace .
    I have a video on Youtube under N1265 if you want to see my original install.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
