Page 5 of 5 FirstFirst 1 2 3 4 5
Results 41 to 42 of 42
Thread: Front winch setups
  1. #41
    4 Star General Keith_J's Avatar
    Join Date
    Aug 2009
    Schertz TX
    Posts
    2,892
    Thanks
    26
    Default
    Quote Originally Posted by gimpyrobb View Post
    Cute, but what is "intermittent" duty cycle? I couldn't find any numbers anywhere.
    From the website, general instruction manual, they recommend no more than 30 seconds of hard pull followed by 10 minutes of cool down. Probably for Australia heat.
    https://sherpa4x4.com/pages/data-sheets
    1986 M1031 SECM.
    1985 MEP 002A
    1974 MEP 026C, eventually converting to electric start.
  2. #42
    Colonel Glockfan's Avatar
    Join Date
    Mar 2013
    Brigham City, Utah
    Posts
    266
    Thanks
    215
    Default
    Quote Originally Posted by rustystud View Post
    Have you had a chance to take it out and try all the new equipment yet ? I'm curious about the new power steering pump. Does it work good at idle ?
    Yes, flawless function. At idle, there is enough flow and power from the pump (4.5 GPM @ 1600 PSI) that I was worried about the winch bolts holding when I tested the function. Adding the winch and ram assist to the circuit provides more capacity overall for the hydraulic fluid. The remote reservoir also adds fluid capacity to the system helping to keep everything cool. The only drawback to the ram assist is that turning the steering quickly from lock to lock is noticeably slower.
  3. The Following User Says Thank You to Glockfan For This Useful Post:
    rustystud (01-12-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
