Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 32
Thread: Is it the M Gator?
  1. #21
    Sergeant Major BadRobot's Avatar
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    I have to change all of plastic body (hood, fenders) parts. Is there any easy way to replace them without remove the cab?
  2. The Following User Says Thank You to BadRobot For This Useful Post:
    USAFSS-ColdWarrior (01-12-2019)
  3. #22
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    These are just a couple of M Gator pictures (in case someone wonder what it looks like). I used these as a reference when I restored mine.
    1.jpg4.jpg5.jpg6.jpg7.jpg9.jpg10.jpg11.jpg12.jpg13.jpg14.jpg15.jpg15.jpg16.jpg17.jpg18.jpg19.jpg20.jpg21.jpg
    Attached Images Attached Images
  4. The Following 2 Users Say Thank You to BadRobot For This Useful Post:
    frank8003 (03-27-2019), USAFSS-ColdWarrior (01-14-2019)
  5. #23
    4 Star General NDT's Avatar
    Join Date
    Dec 2008
    Camp Wood/LC, TX
    MVPA
    4954
    Posts
    7,389
    2,160
    Default
    You gonna have a quad .50 set up as well?
  6. The Following User Says Thank You to NDT For This Useful Post:
    USAFSS-ColdWarrior (01-15-2019)
  7. #24
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    Started up the engine the first time today.
    Costs $2,229.70 until today. She is a runner.
    Most expensive parts will be plastic body parts. I am not sure that I will replace them at this time. I may do plastic welding on the plastic body parts. If it does not work out, then I will replace them at that time.
  8. The Following User Says Thank You to BadRobot For This Useful Post:
    USAFSS-ColdWarrior (01-19-2019)
  9. #25
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    My front left tire had no air and I could not inflate it since the tire was out of the bead. So I had to remove the wheel/tire. Then I discovered this.
    My initial thought was the mechanic wanted to wider the track. Then I put it the wheel back without washers but the rim contacted the steering end rod so I have to put washers back (for now) until I can find new front rims/tires.
    The middle tires do not touch the ground after I inflated tires to 5 PSI. Then I checked tire size. The front tires are the same size as back tires,
    25x13.00-9. That answered my suspicious. Now I have to look for 2 new front wheels/tires.
  10. The Following User Says Thank You to BadRobot For This Useful Post:
  11. #26
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    She got some stitches on her hood and fenders.
    I plan to use plastic welder to weld it, cut zip-ties on the outsides and sand smooth. Then use Raptor bedliner to spray underneath (since I have to spray it on the bed anyway). If it holds up well, I might do on the outsides as well.
    The plastic body parts are quite expensive. The entire set costs around $900.
  12. The Following User Says Thank You to BadRobot For This Useful Post:
    USAFSS-ColdWarrior (02-03-2019)
  13. #27
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    Converted all light bulbs to CREE LED including dash warning light. Added front hitch receiver for snow blower.
  14. The Following User Says Thank You to BadRobot For This Useful Post:
    USAFSS-ColdWarrior (02-12-2019)
  15. #28
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    Around 6PM. The lights are quite bright.
  16. The Following User Says Thank You to BadRobot For This Useful Post:
    USAFSS-ColdWarrior (02-17-2019)
  17. #29
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    Back window tinted.
  18. The Following User Says Thank You to BadRobot For This Useful Post:
  19. #30
    Join Date
    Sep 2015
    Raleigh, NC
    Posts
    152
    29
    Default
    Plastic welded the hood and fenders.
    Before:
    After:
    Before:
    After:
    Before:
    After:
    I will sand it down, Bondo to smooth the outside. I will either repair it or plastic wrap. The inside will be spray with Raptor bed liner.
  20. The Following User Says Thank You to BadRobot For This Useful Post:
    USAFSS-ColdWarrior (02-26-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
