Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 40
Thread: Sherpa winch vs PTO winch
  1. #1
    Sergeant MudMarine's Avatar
    Join Date
    Jul 2018
    Jacksonville NC
    Posts
    95
    Thanks
    62
    Default Sherpa winch vs PTO winch
    Did a quick search about this and didn't see any threads do a straight up comparison on these, especially recently. So I've got a Wo/W truck and have been looking at the options to put one on for the inevitable rainy day when I'll need/wish I had one. I've got a line on a complete PTO set up for only a few hundred more than the 24v 25,000lbs Sherpa winch, but I've got a few questions that make me wonder.
    Is one much better than the other and why?
    Can you run the PTO winch while using the truck in gear?
    The operators TM states to put the transmission in N but it only talks about winching other objects, not self recovery.
    I imagine the Sherpa winch would be an easier install with just having to run cables, but then again the PTO winch is designed to bolt right in.
    Thoughts from the peanut gallery? I mean pros! I did try to do my research here before posting but if I missed the obvious stuff then flame on!
    EDIT: sorry if this should be in the hot rod board, please move if need be Mods
    1988 M35A2c
  2. #2
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,547
    Thanks
    106
    Default
    Pto is more work to install. And it doesnt work if the truck goes dead in the water. The 18v warns are a good winch for a deuce as well. Swampdonkey has the winch installed on his 5 ton and I do mine but I have yet to finish my hookup and he hasnt even tried his either. A buddy of mine does have the 25k mounted on his step deck and double lined it will dead drag a M923 on 4 flats up the ramps with the brakes locked. For the price I bought the sherpa for the amount that I would use a winch.
    2008 F-250 6.4L Powerstroke
    1984 AM General M923A1 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  3. The Following User Says Thank You to simp5782 For This Useful Post:
    MudMarine (01-06-2019)
  4. #3
    LLM/Member 785 Recovry4x4's Avatar
    Join Date
    Jun 2004
    Posts
    33,371
    Thanks
    755
    Default
    Random thoughts in no particular order.
    Let's see. PTO can run all day long without overheating. The truck however, needs to run as well.
    Yes, you can operate the truck in gear. Interestingly, first gear low range and low gear on the winch net about the same speed. In other words, the line speed on the winch will move the truck at about the same speed as compound low.
    The install, while not difficult, is time consuming. The PTO shifter bolts to the master cylinder so if your Air Force deuce has a split system, could be a snag.
    Electric winches are dependable but long recoveries can be taxing on them and your electrical system. They are also fairly easy to install.
    1986 M1008
    1984 M1031
    1984 M1010
  5. The Following 4 Users Say Thank You to Recovry4x4 For This Useful Post:
    73m819 (01-06-2019), Floridianson (01-08-2019), MudMarine (01-06-2019), TGP (IL) (01-07-2019)
  6. #4
    Join Date
    Jul 2018
    Jacksonville NC
    Posts
    95
    Thanks
    62
    Default
    Recovery4x4, thanks for the info on the master cylinder! My truck is one of the lucky few (as I see it) with the dual brake systems! I didn't even think that would come into play!
    It's good to hear that the Sherpa's still have a good wrap, I figured the 25k for 1100 was pretty unbeatable, but to be honest I didn't even consider anything below 20k, like the warn, I was worried it wouldn't have enough umph for a 13k truck once mired in the mud. I did see one thread where someone did some math that supported their use but are they really that much cheaper? I'd definitely hate to drop big money on a winch only to be still stuck with a burnt out winch or snapped line wishing I'd gone bigger... Course I know that can still happen with any winch.
    I'm a little surprised that the PTO seems to be such a chore to install being that it was literally designed to fit... But then again it is the military and the lowest bidder!
    Thanks for the input both of y'all, still looking to hear more opinions because why not haha
    1988 M35A2c
  7. #5
    3 Star General Dock Rocker's Avatar
    Join Date
    Nov 2011
    Jackson ms
    Posts
    895
    Thanks
    186
    Default
    Donít discount the warn 18k severe duty. Itís whatís on the MRAP and many other trucks that are larger than your deuce. One snatch block solves your weight problem.
    They are cheap ($500 ish) surplus. Also you can order parts directly from warn. I have used them with great success over the last few years. I even have its little brother the 12k severe duty on my hmmwv.
  8. #6
    4 Star General cattlerepairman's Avatar
    Join Date
    Jul 2007
    NORTH (Canada)
    Posts
    1,808
    Thanks
    842
    Default
    Quote Originally Posted by MudMarine View Post
    A crane will never reach far enough or lift enough and a winch will never be powerful enough - that is a law of nature. So, I think you are doing the right thing by putting the highest capacity winch on it that you can get/can afford.
    The part that I have not seen addressed is safety. Using the electric winch is a true one-person operation. The PTO winch, really, is not designed to be operated by one person. You can, most of us do, but you really need to be on the ball. The only safety device on the PTO winch is the shear pin (some might argue to some extent, the drum brake). I, personally, prefer hydraulic winches but electric is a close second.
    An empty Deuce w/w, fuel and driver weighs about 6.7 tons (13400 lbs). Recovery wisdom says that if the truck is stuck up to the sidewalls of the tires (so up to the tire bead), you need 100% of the truck weight as pulling power. Up to the hubs, you need 200% and if it is up to the frame, you need 300%.
    Add to that if you need to pull uphill, if it is really sticky, clingy mud etc.
    So, a 25,000 lbs winch is not crazy at all. You will have the advantage that you will need a snatch block less often. The PTO winch came with a snatch block as standard equipment for a reason. The 10,000 lbs straight line pull won't cut it with a loaded truck and/or stuck deeply enough and if you cannot unspool your winch cable far enough and have to winch on the third or fourth layer, good luck with the pulling power that remains.
    As DockRocker points out, even the bigger MRAPs need the snatch block.
    Good luck with your winch attachment and please post pictures of how you do it and how it works out for you!
    MVPA member. 1974 M35A2C w/w "Queen Lola", rebuilt LDS-465-1A, "D" turbo, Waterloo Overdrive upgrade. Med towbar, 11.00R20 Goodyear G286, flipped hubs, remote brake fluid reservoir, bypassed FDC, LED taillights, LED headlights, LED turn signals, WESTACH EGT/boost gauge, AVM lockout hubs, LED convoy light, LED lollipop lights, HMMWV seat on air ride base, M211 dash passenger grab handle, hood lift kit, 24V solargizer/battery minder, ether start kit, flasher module mod, heavy duty dog bone ends, M35A3 aluminium fuel tank.
  9. The Following User Says Thank You to cattlerepairman For This Useful Post:
  10. #7
    Join Date
    Nov 2011
    Jackson ms
    Posts
    895
    Thanks
    186
    Default
    Whatever you choose several properly rated Crosby shackles and at minimum 2 properly rated snatch blocks are a must for a big truck recovery.
    Single lining on a big truck is a bad idea no matter what winch you choose. Use your winch in its best configuration on the last or next to the last layer on the drum and get all of the mechanical advantage from your recovery gear you can.
  11. #8
    Moderator, wonderful human being & practicing Deuce Doctor. Steel Soldiers Vendor clinto's Avatar
    Join Date
    May 2005
    MVPA
    21731
    Posts
    12,387
    Thanks
    1,221
    Default
    Quote Originally Posted by Recovry4x4 View Post
    These are all correct and I agree with all of them.
    I would like to add a comment about the 1987-1989 USAF contract dual circuit trucks.
    They do use a more modern aluminum master cylinder that does not have the provisions for the winch pto shifter to attach to.
    And AM General deserves a lot of credit for this: they cast an ear into the dual circuit master cylinder/pedal assy. mount for the shifter. So if you steal a winch off any 1986-older M44 series truck, you simply bolt the shift lever directly to the master cylinder mount and it'll work. You'll just do away with the u-shaped bracket that mounted the lever directly to the master on the older models.
    So simple - "hey, we're doing this new mount, what about the older trucks with winches that get upgraded? We need to make this new mount backwards compatible".
    https://www.steelsoldiers.com/showth...=1#post1952125
    Click here for the Deuce Doctor-MV Servicing and Sales
    Click here for the Official 2018 Georgia Rally info thread!
    Having a problem searching or finding something on the site? Click here for help!
    __________________________________________________ _____________________________
    MVPA #21731
    1968 Baifield M274A5 Mule
    1967 Kaiser Jeep M35A2 w/w w/dump conversion
    1987 AM General USAF M35A2C w/w
    1987 Turtle Mountain M105A2
  12. The Following 2 Users Say Thank You to clinto For This Useful Post:
    SCSG-G4 (01-07-2019), TGP (IL) (01-07-2019)
  13. #9
    Banned
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,026
    Thanks
    2,257
    Default
    Everyone here provided you good information so I'll just give some personal experience. I've used PTO winches in the woods when I was working as a "yarder" for a logging company. All day running chocker cables. Yes PTO winches can run all day long without any break but you cannot ! Also as was already mentioned you need two people to safely run a PTO winch. While a Electric winch with a remote control is soooo easy to run ! The next question you need to answer is how much are you going to be using this winch ? Are you a contractor who has to remove a stand of lumber ? Or just a guy who will only use his winch on the rare times he gets stuck ? Another thing no one has mentioned is weight. The PTO winch is much heavier then the electric winch. That weight adds up on the front end. Then there is the "free space" factor. Have you tried working along side your engine with the winch driveline in place ? Having to drop your winch driveline every time you need to work on or near the injection pump gets really old fast. Then there is the whole PTO seal thing. There is two seals (one on the driveline side and then there is the control rod seal) that can be another potential leak area. As is the whole PTO unit itself. They can come loose ! Seen it fixed it. Now there is the whole "run" time thing with the electric winch. You cannot just turn it on and start pulling until whatever your pulling is free. The winch motor will burn up and your batteries might get toasted along with your alternator ! So now we're back to what you want to do with this winch.
    I went with a WARN 18000 winch (I'm to old to be working in the woods so I don't need a PTO winch) . It runs great and mounted up easily to the front of my truck. I have two 36,000 Ibs snatch blocks and forty feet of 1/2" 70 grade chain. So far I have never used this winch, but if I ever need to it is ready to go.
    I plan on buying two "Sherpa" winches now. One is the 24,000 Ibs unit for the rear of the deuce and the other is the 17,000 Ibs unit for my new truck.
  14. The Following 3 Users Say Thank You to rustystud For This Useful Post:
    davidb56 (03-06-2019), MudMarine (01-07-2019), TGP (IL) (01-07-2019)
  15. #10
    2 Star General shannondeese's Avatar
    Join Date
    Apr 2009
    High Springs Fl
    Posts
    629
    Thanks
    23
    Default
    On one of my A2s I have a PTO winch installed that I rarely use. On my other A2 it doesn’t have a winch and I have no plans to install one. On my A3 I am adding bumper extensions and a Sherpa 25k winch that I’ll probably only use in an emergency. But I want it available if I ever need it.
    Shannon Deese
    M35A2
    M35A2 Bobbed w/winch
    M35A3
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
