Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Battery replacement ,lithium iron phosphate
  1. #1
    Private
    Join Date
    Jun 2017
    dallas/texas
    Posts
    24
    Thanks
    Default Battery replacement ,lithium iron phosphate
    Any one using LiFePo4 -lithium iron phosphate in the hmmwv?
  2. #2
    2 Star General tage's Avatar
    Join Date
    May 2015
    LOS ANGELES / CALIFORNIA
    Posts
    662
    Thanks
    94
    Default
    Why do you want to switch to Li
    Everything above is my two cents worth. If it offends you, well, deep breath.
    Back from the Bolshevik Exile.
    U.S.A Ret.
  3. #3
    4 Star General BLK HMMWV's Avatar
    Join Date
    Apr 2009
    Pasadena California
    Posts
    1,117
    Thanks
    241
    Default
    And hear I thought 6tl batteries were expensive. Yikes!!
    Why would you want to go to Li batteries
  4. #4
    Private
    Join Date
    Jun 2017
    dallas/texas
    Posts
    24
    Thanks
    Default
    It is expensive.
    I use 1 in my bike.
    It last longer, it had a very slow discharge rate...
    As the hmmwv stays for long periods in the garage, even though attached to the 'noco genius' the battery, is going away.
    I was thinking if someone was using it already.
    I know, it might appear, it is not financially sound option, once we can get 2 high end for the price of 1... but, the system is pretty strong. Thru time, the return is there.
  5. #5
    2 Star General TOBASH's Avatar
    Join Date
    Jan 2017
    Brooklyn, NY
    Posts
    677
    Thanks
    464
    Default
    Here's an idea...
    Disconnect the batteries when not in use, use a de-sulfating solar charger type device to extend longevity, drive the vehicle more often.
    If not, then spend the $$$$ for Odyssey batteries, a dry lead battery.
    I love Odyssey batteries, but I don't let them sit.
    Odyssey batteries are not Li batteries, but the are kick @$$.
    If you have an alternator failure and you overcharge the batteries, Li batteries may catch fire/explode. Given they are under the passenger seat, that is a disaster waiting to happen.
    Your call.
    Best,
    T
    T.O.B.A.S.H - When we feel frustrated with those around us. LOL
    The Great Wall of China is regarded as one of the Seven Wonders of the World. What is wrong with The Greatest Country in The World building its own???
    1987 M1025 Slantback, 6.2 w/3 speed
    2017 Tesla Model X P100D
    2011 Tesla Roadster
    2003 Lifted Durango with steel bumpers
    1984 Toyota BJ-44 RHD
    Restoring 1975 Toyota Iron Pig
  6. The Following 2 Users Say Thank You to TOBASH For This Useful Post:
    cucvmule (01-11-2019), tage (01-11-2019)
  7. #6
    Colonel
    Join Date
    Jul 2017
    Crystal City Mo
    Posts
    337
    Thanks
    971
    Default
    That there TOBASH would be a Very Good reason not to use inside the Vehicle.
    Batteries of any kind are a very seriously underestimated hazard that although very useful can turn on you in a FLASH. Been there, and have seen it happen.
    You may in your lifetime never see the explosion. But why take the Chance? I use at minimum safety glasses when ever I have to work close to any battery. Silver necklace burn from arching, laying over battery to tighten alternator belt. YIKES!
    Belt Fed Multi Barrel Motor Motivated
    Help From Above
    GAU 8 See You Next Time
  8. The Following User Says Thank You to cucvmule For This Useful Post:
    TOBASH (01-11-2019)
  9. #7
    Private
    Join Date
    Jun 2017
    dallas/texas
    Posts
    24
    Thanks
    Default
    those type of batteries are very safe. they are the safest over all.
    no catching fire or exploding.
    the charging process was my concern, even there, the documentation says it is a superior system.
  10. #8
    Sergeant Major
    Join Date
    Mar 2016
    Adams NY
    Posts
    193
    Thanks
    Default
    Each battery system could be labeled as superior for their intended applications. It's been my experience that typical lead acid batteries are best for the starting systems of vehicles.
  11. #9
    Colonel riderdan's Avatar
    Join Date
    Mar 2017
    Central Kansas
    Posts
    268
    Thanks
    53
    Default
    I solved my battery problem (with Walmart batteries no less) by installing a battery balancer and running a 24v charger through the NATO slave plug. I plug the truck in overnight about once a week when it's not being regularly driven and I haven't had a problem since I switched to this method--after having two batteries die (probably from old age). With the NATO plug, it takes about 60 seconds to attach the charger, and the battery balancer allows the charger to charge both batteries to capacity.
    There's no such thing as overkill. There are just "Open fire!" and "Reloading"
  12. The Following User Says Thank You to riderdan For This Useful Post:
    TOBASH (01-13-2019)
  13. #10
    4 Star General Keith_J's Avatar
    Join Date
    Aug 2009
    Schertz TX
    Posts
    2,853
    Thanks
    22
    Default
    The advantages of the LiFePO4 chemistry don't make for any advantage in automotive starting systems, even with glow plug diesels. We never use more than 20% of the charge even in arctic conditions. Which is why the selling point of cold cranking amps is far more common than the amp-hour capacity.
    Now if you are deep discharging to 80% or more, then the Li family makes sense. PbSO4 just doesn't like deep discharge, even valve regulated recombinant absorbed glass mat.
    LiFePO4 isn't the same fire hazard as lithium polymer (typical cell phone), lithium ion (power tool and computer) or lithium metal (primary or one time use) types. Only lithium metal have the class D issue (metal fire).
    Save your coins, spend them on the ponies at the track. You will have a better payout.
    1986 M1031 SECM.
    1985 MEP 002A
    1974 MEP 026C, eventually converting to electric start.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
