Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: M816 14.00 duals
  1. #1
    Private
    Join Date
    Dec 2018
    Climax,GA
    Posts
    13
    Thanks
    Default M816 14.00 duals
    Dual 14.00x20. Flip rear hubs, bridge truck wheels on inside, regular wheels that came on the truck on outside, yes they will fit nicely on the wheels. Air up to 60psi and there will be about 1&1/4 inch of spacing between duals on a heavy 816. You do not need any kind of spacers.
    Attached Images Attached Images
  2. The Following 9 Users Say Thank You to lighten For This Useful Post:
    4x4 Forever (01-13-2019), 98G (01-11-2019), Ajax MD (01-12-2019), country (01-11-2019), Jbulach (01-11-2019), NDT (01-11-2019), pontiac62 (01-11-2019), silverstate55 (01-12-2019), tobyS (01-13-2019)
  3. #2
    4 Star General Scar59's Avatar
    Join Date
    Mar 2013
    Mt. Eden, KY
    MVPA
    35048
    Posts
    2,686
    Thanks
    Default
    Looks aggressive, nice foot print.
    I'm not saying let's eliminate all the stupid people. I'm just saying let's remove all the warning labels and let the problem work itself out.
    1997 M35A3C, 1987 M35A2C, 1973 M35A2C, 1971 M813A1 W/W, 1985 M931A1, 1985 M925, 1972 m817, 1984 M936, 1984 M923, M105A1 (4ea), 1972 M38A1, MEP 002a on M116A3. MEP531A, MEP501s
    2 dogs, 2 cats
    MVPA, NRA, AOPA
    Satisfied BEEFCO customer.
  4. #3
    4 Star General Jbulach's Avatar
    Join Date
    Nov 2013
    Sunman Indiana
    Posts
    1,470
    Thanks
    2,149
    Default
    Cool. How wide does that make you?
    M925A2
  5. #4
    4 Star General 98G's Avatar
    Join Date
    Aug 2013
    AZ/KS/MO/OK, varies by the day...
    Posts
    4,014
    Thanks
    5,995
    Default
    Quote Originally Posted by Jbulach View Post
    98" with 11.00's. The 14.00's should put it about 104" at minimum and possibly a good deal wider.
    Legal max is 102" without using placards.
    I like the way it looks. The stance is spot on. This should also increase load handling and crane stability.
    I'd be interested in a measured width instead of my guesses.....
  6. The Following User Says Thank You to 98G For This Useful Post:
  7. #5
    Private
    Join Date
    Dec 2018
    Climax,GA
    Posts
    13
    Thanks
    Default
    It measures right at 111" wide. The crane is coming off at some point. I am gonna try to put a big hydraulic winch in its place, and figure out some sort of pump for it.
  8. The Following 3 Users Say Thank You to lighten For This Useful Post:
    98G (01-12-2019), Jbulach (01-12-2019), silverstate55 (01-12-2019)
  9. #6
    Administrator steelsoldiers's Avatar
    Join Date
    Aug 2003
    Charleston, WV
    MVPA
    22215
    Posts
    4,974
    Thanks
    452
    Default
    Quote Originally Posted by lighten View Post
    You gonna build some fenders to cover the outboard tires or can you run it like that in your state without getting a visit from the fuzz?
    Chris Stansbury, founder of Chris' CUCV Homepage in 1998 and Steel Soldiers in 1999.
    Current:
    1962 Dodge M37B1
    Gone, but not forgotten:
    M1009, M35A2, M1009, M561, 404 Mog, M818, M923A2, M931A1, M1008, M925A2, M998
    HUGE M925A2 Build Thread: https://bit.ly/2uPlSnZ
    HUGE M923A2 Build Thread: https://bit.ly/2uO2g3K
    Father, lead me, 'cause I can't do this alone.
  10. #7
    Private
    Join Date
    Dec 2018
    Climax,GA
    Posts
    13
    Thanks
    Default
    Quote Originally Posted by steelsoldiers View Post
    I been running it like it is. Its company use only(not for hire) and the fuzz knows what we do around here, so we won't have any problems.
  11. The Following 2 Users Say Thank You to lighten For This Useful Post:
    98G (01-12-2019), steelsoldiers (01-12-2019)
  12. #8
    Colonel 8madjack's Avatar
    Join Date
    Jun 2016
    Gold country Ca.
    Posts
    220
    Thanks
    52
    Default
    Love that look!
    Forgive my ignorance, what hubs are you flipping?
  13. #9
    3 Star General Iceman3005's Avatar
    Join Date
    Mar 2011
    Jonesville, MI
    Posts
    817
    Thanks
    146
    Default
    That looks sweet! Could this be done with 53's Michelin's?
    1984 M1008 CUCV- SOLD
    1984 M1008 CUCV daily driver Turbo 6.2diesel, 4L80E, np208, dana 60 front, gm 14 bolt w/locker rear
    1989 K-5 blazer (not a CUCV) 350cid, 700r4, np241, gm10 bolt rear, gm 12 bolt front
    1987 Chevy 4 door 1 ton dually (not a cucv) 454cid, turbo 400, np205, dana 60 front, dana 70 rear (Cummins removed from a 95 dodge, getting it torn done, cleaned, and painted.)
    1970 M813
    https://www.facebook.com/groups/4093...?ref=bookmarks
  14. #10
    Join Date
    Aug 2013
    Posts
    4,014
    Thanks
    5,995
    Default
    Quote Originally Posted by Iceman3005 View Post
    I doubt it. At least not without spacers between the wheels.
    And what you can get away with empty will change with a load and some sidewall flex.
  15. The Following User Says Thank You to 98G For This Useful Post:
    tobyS (01-13-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
