Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Bigcam 3 400 extra long cold start 40f
  1. #11
    2 Star General
    Join Date
    Apr 2012
    Washington
    Posts
    641
    Thanks
    62
    Default
    Just to add a little more info, my m809 with the NHC 250 will crank for about 10 seconds when it's 30-40 degrees out with the smoke getting progressively thicker until it fires off. Once it kicks off it just purrs while it builds air.
    If I plug in the block heater, it fires right off like it was just running 5 min ago no matter how cold out.
    I always use the block heater these days if I know I will be running it and temps are expected to be under 40.
  2. #12
    Sergeant akita91's Avatar
    Join Date
    Jan 2018
    CREVE COUER , ILLINI
    Posts
    75
    Thanks
    86
    Default
    i will look up those leaks then get back here
    this one fires up ,im just guessing whats my issue
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
