Bigcam 3 400 extra long cold start 40f
akita91
CREVE COUER , ILLINI
Whats the common problems with hard start ? i have 2 batteries, both charged,it takes at least 2 cranks each about 15-20 sec before it fires up.missing ,dies if i keep foot of throttle ,gotta hold for about another 15-30 sec wot , rpms slowly crawls to 2100.
Ive read some threads here and other places,it could be pump,cylinder comperssion or else ?if its above 50 ,starts right up
Elijah95
Certified Rookie
1,239
1,183
Georgia
Have you ruled out the possibility of fuel drain back? Losing prime can make a mess out of a perfectly good engine on initial start up
162tcat
44
Washington
I think he nailed it. Sounds like you have an air leak somewhere between the pt pump and tank.
simp5782
Feo, Fuerte y Formal
9,259
Mason, TN
Have you replaced the fuel filter recently? The check valve may be allowing backflow or a bad gasket. Check that before replacing the line. It is a 1/2in fuel hydraulic line. Ditch that and go with 5/8 or 3/4" push lok line and fittings. So you get more fuel flow for added power.
sandcobra164
287
Leesburg, GA
Sounds about like the NHC-250 in my 5 ton in the cold if I don't use the ether start. It can be parked for a month and fire off in 2 seconds if the temps are warm. Do you have white smoke while you are cranking when cold? If so it sounds like you're truck is doing just fine.
162tcat
44
Washington
Before you start spending money on expensive parts start with the cheap basic items. Fuel filter was recently changed so it may not have seated properly. Fuel line replacement is a maintenance item, I would just do it to rule that out and for piece of mind. If that doesn't fix it, start diagnosing other stuff. Have you thought about a block heater? If it's just cold blooded that will help tremendously.
162tcat
44
Washington
Just to add a little more info, my m809 with the NHC 250 will crank for about 10 seconds when it's 30-40 degrees out with the smoke getting progressively thicker until it fires off. Once it kicks off it just purrs while it builds air.
If I plug in the block heater, it fires right off like it was just running 5 min ago no matter how cold out.
I always use the block heater these days if I know I will be running it and temps are expected to be under 40.
