Results 1 to 8 of 8
Thread: M37 Gun Truck Questions
  1. #1
    Senior Chief/Moderator hndrsonj's Avatar
    Join Date
    May 2004
    Cheyenne, WY
    MVPA
    31099
    Posts
    7,416
    Thanks
    998
    Default M37 Gun Truck Questions
    So the M37 is way smaller than a deuce, so what did they carry in the back and how was it stowed? Any inside pics would be great. Thinking of building one with my 2nd M37.
    1951 Reo M48 Deuce Tractor
    1962 Dodge M37B1 w/w
    1951 Willys M38
  2. The Following User Says Thank You to hndrsonj For This Useful Post:
    maccus (01-19-2019)
  3. #2
    4 Star General frank8003's Avatar
    Join Date
    May 2012
    Ft. Lauderdale, Florida
    Posts
    4,007
    Thanks
    2,818
    Default
    Individual and vehicle load outs have changed very little from the 50's
    until now out side of improved fire arms.
    The document is so large I cannot get it to post.
    Here is the recommended load out:
    You need to substitute period fire arms for the ones listed here as some of these were just a thought then:
    (1) Individual basic load recommendation:
    M16 210 rounds 1 tracer : 2 ball
    M203 40 rounds (mix HE – 30 / Smoke – 10)
    M249 1,000 rounds (preferably in drums)
    M2 500 rounds 4:1
    M240B 1,600 rounds 4:1
    MK-19 128 rounds
    Hand grenade 4
    (2) Vehicle combat load:
    Additional basic load as listed above in the vehicle,
    configured so it can be used while driving and easily taken from the cab if dismount
    becomes necessary.
    In addition, the following should be in all vehicles:
    HC smoke grenade 2 White star cluster 2
    Red smoke grenade 2 Red star cluster 2
    Violet smoke grenade 2 Green star cluster 2
    Yellow smoke grenade 2 White parachute flare 6
    Green smoke grenade 2
    a. Harden vehicles with sand bags, steel plating, wire mesh, ballistic blankets,
    extra fragmentation vests, or any other material that will add protection
    while not handicapping mobility.
    b. Ammunition allocation and location needs to be standardized with both
    an individual basic load and a vehicle combat load.
    5. Intelligence is often the weak link in the mission planning process.
    Units need to develop a system of receiving daily intelligence briefs,
    posting the map in the company operations room.
    I was here, had a good time.
  4. The Following User Says Thank You to frank8003 For This Useful Post:
    Wolfen (01-19-2019)
  5. #3
    Join Date
    May 2012
    Posts
    4,007
    Thanks
    2,818
  6. #4
    General maccus's Avatar
    Join Date
    Jan 2005
    Custer, South Dakota/Black Hills
    Posts
    522
    Thanks
    599
    Default
    Jim have Dan stop on his way down to your place as I have 2 doors and a front bumper that need to go your way. All are totally rust free. The bumper came off of the blue AF M37. The bolts had not one spec of rust on them so it was just like taking the nuts off of a new vehicle. The parts on the other 2 M37s are ok but not as nice, One has a non stuck engine with all the issue items on it, also have 3 good (need rad shop to check them) radiators if you need one for the gun truck.
  7. The Following User Says Thank You to maccus For This Useful Post:
    papabear (01-25-2019)
  8. #5
    Join Date
    May 2004
    Cheyenne, WY
    MVPA
    31099
    Posts
    7,416
    Thanks
    998
    Default
    I do need a radiator for the engine in the garage on the stand....
    1951 Willys M38
  9. The Following User Says Thank You to hndrsonj For This Useful Post:
  10. #6
    4 Star General jeffhuey1n's Avatar
    Join Date
    Mar 2010
    Laramie County, Wyoming
    Posts
    1,252
    Thanks
    1,041
    Default
    Any spare engines you may have lying around would look good in my 37
    3 each M35A2's 2 WO/W, 1 W/W:
    1972 M35A2 WO/W “Toys For Tots”, aka “Armadillo”
    1972 M35A2 WO/W “Tribute to Lt Col Ken Bourland”, aka “Warthog”
    1970 M35A2 W/W “War Wagon”, Vietnam War Gun Truck Tribute
    1 each M59 gasser dump truck
    2 each M211's 1 W/W, 1WO/W
    1 each M52A2 tractor
    1 each M1009
    1 each M37, with Dodge poly 318, hydraulic clutch
    1 each G506 Fire truck “Sparky”
    USMC/USAF
  11. The Following User Says Thank You to jeffhuey1n For This Useful Post:
  12. #7
    4 Star General vtdeucedriver's Avatar
    Join Date
    Feb 2006
    Vermont
    Posts
    2,525
    Thanks
    506
    Default
    Quote Originally Posted by hndrsonj View Post
    I got pics, I will dig them out sometime soon. I'm not up for typing all day so I will give you the short end description on what your looking for. Steel plate, some was scratch stuff laying around and others had pieces of the kits that were made for deuces and 5 tons for troop protection. NO SANDBAGS!!!! those went by the wayside in 67-68 after the Monsoons when they got wet. The M-37 will sag like no other once the steel is on. As for loadout. There WAS NO TOAE. Table of authorized equipment for a Gun Truck in Vietnam. It was whatever a crew could get their hands on. Your not going to mount 4 ma deuces in a M-37 very well so in country, One M2 and maybe a M60 mounted in one truck. One well known one had a twin 60 mount that was scratch built that worked fine. Will need a radio in the back to stay on frequency with other GT's in a convoy so an RT-524 mounted in the corner will work. Plenty of ammo for whatever your main fire suppression is. You will also need whats called a "ditch gun". If Victor Charles gets close to the road, he could get close enough to where the main gun cant be brought to bare to his location. This is where a ditch gun can be brought over the side for close support. The driver will have his hands full working the kill zone but there are times where he might have a min to get behind an M79 and put a few rounds out. So that's a start for firepower.
    Convoys are long, slow and hot. "dust cutters" of a good beverage should be on board. Not need to be cold but Hams or Budweiser purchased from the PX or possibly traded from the Air Force at Pleiku. C rations are a definite, ditch the ham and mutha ****ers as those were usually pitched to the kids in the small villages that looked for handouts as convoys went through. Peaches and Pound Cake were saved in the evening back at base or on RON (remain over night) at a firebase or Bridge. GT's were often used for this type of duty after hours. So after hours, reading material on the truck. Playboys and car magazines were at the top of the hot items. More dust cutters or "Other" types of relaxation method could also be found. In the central highlands, spending the night in a truck meant you needed a Wooby (poncho liner) or Field jacket. I know a few drivers that kept sleeping bags with them for just these occasions. If you don't have the room, just go tropical and sleep under the truck and forget above as that was done too.
  13. The Following 3 Users Say Thank You to vtdeucedriver For This Useful Post:
    jeffhuey1n (01-25-2019), microjeep (01-25-2019), Storm 51 (01-28-2019)
  14. #8
    Join Date
    Mar 2010
    Posts
    1,252
    Thanks
    1,041
    Default
    Thank you for the info! Is it safe to assume that most every gun truck, regardless of size, could be equipped the same way? My War Wagon has:
    plywood backed sheet metal for armor, three M23 equiliberator mounts with ammo trays for three .50 M2’s, one ground M60 ditch gun, one M-16A1 personal weapon, 4 plus lemon grenades, 2 spent smoke grenades, one spent LAW rocket tube, gas mask, canteens, two litters, two fold up cots, RT-524 radio with the correct antenna mount and antenna, VIC-1 intercom with headsets and stations for four personnel, stand alone speaker, water cooler (correct model for the late ‘60’s), Mermite can, foot locker stuffed full of misc stuff, 140+ .50 ammo cans, which covers the floor, several 7.62 ammo cans for the M-60, linked dummy .50 and 7.62 for the weapons, helmets, flack vests and first aid kit in a 20mm ammo can. Note: all weapons are replicas or spent real ones that can no longer be reused.
    still looking for a M79 replica. I found a source for 40mm grenades for the M-79. I’m saving up my pennies until I can buy them. Also looking for another M23 and another M2 so the rear mount can be a double mount.
    1 each M1009
    USMC/USAF
  15. The Following 2 Users Say Thank You to jeffhuey1n For This Useful Post:
    chopsm1 (02-18-2019), papabear (01-25-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
